Features Falcons done right?
Discussion in 'The Hokey Ass Message Board' started by guiseart, Nov 20, 2005.
  1. MrModelT
    MrModelT
    I certainly would be interested in whatever info I can get on retrofitted or modded suspension on these Birds....planning to replace all the suspension in my American '65 sedan with all Shelby GT:350 "R" code stuff. This is uncharted territory for me.
    Will read over the tech thread and might just send you a PM or two.
  2. 1971BB427
    1971BB427
    from Oregon
    Here's the '63 Falcon Futura 2dr sdn I just picked up last week. All stock now with 6 cyl. three speed. It's going to go through major changes once I start building it into a g***er with 454 Chevy power, 4 speed, 9" Ford, and Econoline straight axle.
  3. Hodgebilt
    Hodgebilt
    from Montana
    Hey guys and gals this is my 62. I havent had it long but we just recently painted it. Its suede purple with a gold top. The picture doesnt do it justice but its a work in progress. Ill post more as they come. I have been looking at doing a set of wheel vintique 15x7s and I was wondering if anyone else has done a seven inch wide wheel on there car. uploadfromtaptalk1359650540570.jpg
    Sent from my DROID device using the TJJ mobile app
  4. hotroddon
    hotroddon
    Looks good. A 7" wheel is pushing it on these cars, especially when lowered. You really have to watch the offset. To much back spacing on the front will rub the control arms during turning and too little will rub the fender. In the rear, on a lowered car you have to watch both leaf spring clearance and inner fender well.
    Bot saying it can't be done, but you have to nail it spot on.
  5. need louvers ?
    need louvers ?
    My '62 coupe has a 7" wheel on the rear, but it has a Maverick rear narrowed about 2" (two short side axles) with 3.5" of backspace and a 195/65-15. With it lowered about 4" total, rear tire changes are an all afternoon kinda deal...
  6. Hodgebilt
    Hodgebilt
    from Montana
    The wheels I was looking at have a 4 inch backspacing. I can imagine changing the back tires is going to ****.mine is sitting at about 3 inches of drop and its pushing it. Ive heard using newer dodge steel wheels work decent because they are 15x6s but im not sure. I would imagine that they would be primarily front wheel drive offset and im sure thatd pull them in to far. I got to do some measuring.
  7. need louvers ?
    need louvers ?
    I'd sure stick with 15x6 myself, with about 3.5-3.75 backspace. If for some reason a 4" backspace got into anything you could run a 1/2" spacer though. We have had several discussions on tires and wheels over on the "TECH" thread "Doing Falcons Right"...
  8. Kustom.Falcon
    Kustom.Falcon
    On a round bird, I'd go 6". Really, I'd go for a 14x6, but that's me. I'm running a 15x7 reverse on a narrowed rearend, and a 15x6 standard in front to maintain any sort of turning radius.
    NEED LOUVRES I scoped you out at the GNRS, shoulda said hi. Catch you next year?
    Kustom Falcon Build Thread:
    http://www.jalopyjournal.com/forum/showthread.php?t=734282
  9. need louvers ?
    need louvers ?
    Absolutely! Wish ya would have given me a shoulder tap and a handshake. How did you know what I looked like?
  10. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    I run 16x6 Cragar SSs 195s in the front 205s in the rear. I had to m***age the rear fender wells a lot to keep from rubbing. 2 inch block in the rear. I also had to extend the shock rod so the rear would drop far enough to get the tire out in case of a flat. Ask me how I found this out??
  11. Kustom.Falcon
    Kustom.Falcon
  12. Evilfalcon1961
    Evilfalcon1961
    from Ma
    someone sell me some cal custom 4 lug spider caps!
  13. need louvers ?
    need louvers ?
    Forgot about the tags! I wore mine for about an hour later and was getting some sort of weird stares from the "normies" out there, so I took it off. I thought about putting "occupant" on it but thought that would rather defeat the purpose... The one rule with me is you should alway interrupt, 'cause I never stop talking - Next year man! Your Falcon is looking great!
  14. Kustom.Falcon
    Kustom.Falcon
  15. Leon Sandcastle
    Leon Sandcastle
    About to do a Ming Green paint job on my 62 four door... Hope this works out.
    Posted from the TJJ App for your mom
  16. bonez
    bonez
    from Slow lane
    I looked for them for years. They always popped up when i had no money or something.
    Of course now that i dont need them anymore they seem to surface a lot more often LOL
  17. Bigcheese327
    Bigcheese327
    Given their scarcity, I wonder if it wouldn't be cheaper to do a five-lug conversion. After all, your time is worth something too.
  18. DRM ON
    DRM ON
    from Australia
    a couple pics of my old ute.
    Almost sold it a couple of weeks back and the sale fell through. For some reason that really motivated me to finish it. Should be on the rd in a month or so I reckon ($$$$ permitting) Just finished making all new brake lines for it. got a tonneau cover made up for it, mounted the seat and everything properly, just need to fit the tailshaft, wire it up finish the 4 link (2 more arms to go) and well be ready to cruise the wheels off it
    this is where it all began. Dont ask me how I saw potential in this but I did haha
    and now
    exterminator likes this.
  19. Liam-B
    Liam-B
    from Melbourne
    Hey brad, fancy seeing you here?
    A lot of love for the old Falcons on this forum! Glad you decided to keep this one and follow through finishing it, looking forward to seeing it one day :)
  20. ausbuick
    ausbuick
    That is one bad *** xk dude..
    It makes me want an early falcon again
    cheers Darren
  21. bonez
    bonez
    from Slow lane
    Yeah, itsa good idea, and something im thinkin of doin. It will **** not rollin on 4 spoke Cragars, or any other 4 spoke mag, but there are far more pros than cons. Gotta redrill the hubs thou, cause i still wanna roll 13s.
  22. DRM ON
    DRM ON
    from Australia
    yeh ive been a long time lurker but dont post very often.
    Im pretty keen to get stuck into the old ute now. Shouldnt be long and it will be ready for rego
  23. DRM ON
    DRM ON
    from Australia
    thanks mate.
  24. Alfster
    Alfster
    On the subject of the 4 spoke spinners. Does someone have one that a pattern can be taken off to get some cast? Shouldn't be that difficult. Or make a pattern to cast some yourself. Could be a market for them.
    I am looking for a set of 3 spoke spinners to suit SS Cragars and can't find any so I will have to make a pattern to have some cast.
    Yes, I know I can buy them new from Summit and other places but by the time I pay the exchange rate and shipping the price is way too expensive.
  25. falconsquire
    falconsquire
    More pics as requested. Please don't hate on the modernness of my car. The wheels are the standard sports pack option when these came out I think thu are the beat wheels for ever made. It's half painted as bubbles started coming back. Best thread on the hamb.
    <a href="http://s1162.photobucket.com/albums/q537/falconsquire/?action=view&current=3B510155-2582-48E3-BE40-19B76325164D-2453-0000028102C99C43.jpg" target="_blank">[​IMG]</a>
    <a href="http://s1162.photobucket.com/albums/q537/falconsquire/?action=view&current=ED0D2404-E7EA-442C-AC33-B3A8EA33313F-2453-00000280C01F8E52.jpg" target="_blank">[​IMG]</a>
    <a href="http://s1162.photobucket.com/albums/q537/falconsquire/?action=view&current=01FB0B38-ABF6-4ABD-BB92-90EE42008153-2453-00000280DA8E8D9A.jpg" target="_blank">[​IMG]</a>
  26. DRM ON
    DRM ON
    from Australia
    Such a cool wags mate. Love it. These would be the best holiday wagon as they're so big haha. Does yours have the 2 way tailgate.
  27. hotroddon
    hotroddon
    Thanks to President's Day and the fact that I got the 29 RPU done and off to it's owner, I got to work on the Falcon today. Hadn't touched it for a year. I fabbed, modified and mounted the Shelby 'R' Apron and am pretty happy with how it came out.
  28. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Nice! I like the look- gonna' paint ta' match?
    I'd leave it black but I'm pretty squirrelly....
  29. Alfster
    Alfster
    That certainly looks different. Would be interesting to see it painted to match the rest of the car. Or maybe a race theme with something like white Shelby stripes from front to rear. Now you have started you have to keep the theme going.
  30. hotroddon
    hotroddon
    Oops just realized I posted this in the wrong thread, meant to do it in the Doing Falcons Right. Any way, when I do the rest of the body mods I think the car is going back to original white with a couple of Shebly stripes in Blue.
