Any studebaker truck guys? I got some questions?
Discussion in 'The Hokey Ass Message Board' started by tlmartin84, Feb 11, 2013.
  1. tlmartin84
    tlmartin84
    from WV
    First off: What would a 1954 STUDEBAKER PICKUP be worth?
    Body is in excellent shape, minor sheetmetal repairs needed, minor rust. No major surgery required.
    No Motor or transmission.
    Next up, where is a good parts source for them? Any places like LMC or anything like that?
  2. Hard to say about value 750-1500. As far as I know there are no aftermarket sheetmetal parts made for Stude pick ups. Most of the stuff is pretty simple, so I just make my own. FWIW, LMC sells absolute garbage anyway.
  3. LOWBLAZERO1
    LOWBLAZERO1
    cl***ic enterprises is about as close as you'll get to an lmc for studes.
  4. tlmartin84
    tlmartin84
    from WV
    Any good websites just for general information on them? I have no idea about what engines came in them or anything.
  5. They have a really active club. Most of them are into stock stuff. Lots of NOS mechanical parts around.
  6. aircap
    aircap
    Check out the Studebaker Drivers Club website for a list of Studebaker Vendors - there are plenty of truck parts available.
    Also - log onto the Forum of the club, and log onto the Studebaker Truck Talk forum.
  7. stillrunners
    stillrunners
    from dallas
    yes SDC is a good source - 1954 should be the first year for the 1 piece windshield and the factory V/8 which was first used in the 1951 Commander. Most Cab and front sheet metal go up tp 1959 with grille changes yearly on the 1/2 ton - they kept the cab on big trucks up to 1964. The step side bed was used up to 1964 - so that bed goes from 1949 to 1964....
  8. stude_trucks
    stude_trucks
  9. mbstude
    mbstude
  10. vh1950
    vh1950
    For parts & info try studebaker international, greenfield, in
  11. BenW455
    BenW455
    Show us some pics.. Where in WV are you?
  12. tlmartin84
    tlmartin84
    from WV
    Lewisburg......
    Keep tabs on this thread I'll post a few tommorrow.
  13. BenW455
    BenW455
    Cool I am in Beckley, WV. Used to work a lot in Lewisburg.
  14. 32cruisin
    32cruisin
    Do a google search for Stuebaker Truck Talk Forum. Nothing but truck talk.I found out so much on there when I was building my 48 M. Good luck.
  15. tlmartin84
    tlmartin84
    from WV
    Here they are guys. Everything is in good shape except the following areas:
    -Door bottoms need cleaned and worked.
    -Under the rocker panels needs some metal back in them, straight strips nothing too bad.
    -front left fender needs replaced (there is one in the bed in good shape)
    -tailgate is rough (also one in the bed in good shape)
    Needs a motor and ******. Thats about it really. With the exception of the inner cab corners and those rockers the bottom of the truck looks solid. Someone has done some work and painted it though so thats a little iffy. All fenders look good, no rust through on the inner sides.
    What do you al lthink its worth?
  16. funk 49
    funk 49
    I also use Stude International for things I need stock.
  17. Apenaut
    Apenaut
  18. I would be a little weary about what's under that re-paint....
