1957 Ford Running Rich
Discussion in 'The Hokey Ass Message Board' started by daren, Feb 12, 2013.
  1. daren
    daren
    My dad just bought a 57 Ford. Y-block, 239. Has the original carb...2 barrel. Its running rich and fouling out the plugs. This carb looks like a holley 2300...but there are no mixture screws on the side of the metering block like most holleys! How do you adjust this carb?...Im not near the car now for pics or numbers...can get that tomorrow after work...An ideas?
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    Well first off 57s did not have 239s that was 54 only, you have most likely a 272 being that it has a 2bbl. Look down low on the carb base front side for the screws.
  3. carlos
    carlos
    from ohio
    Old guy told me years ago son you have an ignition problem reason you are fouling plugs he was right:D
  4. Dan Timberlake
    Dan Timberlake
  5. hoop98
    hoop98
    from Texas
    The mixture screws only affect idle and even full rich couldn't foul plugs.
    That carb has a vacuum diaphragm power valve. When the diaphragm fails it will **** fuel straight into the manifold causing a gross rich condition.
    http://www.holley.com/data/Products/Technical/199R10013.pdf
    The reason they fail could be age or backfire, as listed in another thread you can get a backfire protector.
    jm2c
    rh
  6. daren
    daren
    Thanks for the help!
  7. hoop98
    hoop98
    from Texas
    A properly jetted car running on the main or cruise circuit should be a touch lean.
    Put it up to about 2500 RPM and block the throttle to hold it at a fixed RPM.
    If you introduce a good sized vacuum leak it should miss a bit or lose some rpm.
    If you get a substantial increase in RPM the there is too much fuel available.
    If there is no increase or a miss you can use propane to see how lean you are.
    These cars ran on the rich side but I would expect to see 50 - 150 RPM bump a you slowly meter propane into the airhorn.
    Go slow and fine tune to get the maximum RPM.If you get a big jump in RPM, 200 -500 then the primary metering is too lean.
    Remember too rich can be cause by many factors, float level, flooding, internal carb leaks.
    In summary if adding air cuses a RPM gain, you have excess fuel, if adding fuel causes an increase you have excess air.
    This link is for checking vacuum leaks with propane but the general idea is the same.
    http://www.highperformancepontiac.c...to_identify_engine_vacuum_leaks/photo_12.html
    Use common sense, if you are unsure, just don't do this. This is how I would check the mixture control when the first electronic carbs hit in 78.
    Hoop
    CAUTION
    Propane is a flammable gas. Observe "no smoking/no open flame" precautions. Have a Cl*** B-C (dry powder) fire extinguisher within arm's reach at all times.
