Projects My Shoebox Dash Metalflaking + Hidden Radio Laid Off $0 build
Discussion in 'Traditional Customs' started by Mr.Dickies, May 10, 2012.
  1. EBW
    EBW
    Wow.. impressive !!
  2. BadLuck
    BadLuck
    that motor is awesome!
  3. Blake84
    Blake84
    Def gold and chrome in your shoebox!!!! Looks awsome
  4. Buddy Palumbo
    Buddy Palumbo
    The motor looks cool in gold .
  5. Mr.Dickies
    Mr.Dickies
    Thanks guys I love the gold. I decided I'll pull the shoebox motor trial fit it into the HJ then paint it and put it back into the shoebox after it's painted gold. Engine bay white?
    CJ
    I'll be seeing your ride later today with Tyler and the Boss! I'm super excited to see it. Mine won't make it this year. But next year for sure.
  6. tedley
    tedley
    from canada
    Good choice on engine and underhood color. :)
  7. BadLuck
    BadLuck
    right on! just ignore all the water spots tho.. i guess the roof of the building has been leaking right on top of my car :( Well try to find me and say hi.. were headed down there in a bit too
  8. DadsBlueFord
    DadsBlueFord
    from Hayden, ID
    What did you use to remove the paint?
  9. Mr.Dickies
    Mr.Dickies
    Screwdiver sandpaper wire wheel and a whole lot of elbow grease! I tried stripper but it just laughed at me and made a mess! I was about to give up but had extra time when my son Tyler got sick and couldn't start a huge project. Had to keep busy during nap time some how. Gold flake paint is thinner than water!
  10. Mr.Dickies
    Mr.Dickies
    My top picks of GNRS 2013!
    Tyler's pick! 59 El Co with This is not that kind of car please don't touch in the window but Mr Happy charmed his way into sitting in it!
  11. Mr.Dickies
    Mr.Dickies
    Been plugging away on the little things while I wait for my mandrels to get here to mold in the side pipes. Stupid kid tried to steal my Zombies CC plaque off the back. Fixed the front spalsh pan what a pain in the ***. It never fit well so I hammered it out and now it fits so much nicer. Its funny how much different it fits now. I use to have to put all the bolts in and tighten everything down just for it to fit like ****. I'll primer it tomorrow since it's going to be 81' out in SOCAL!
    WHATS YOURS GUYS THOUGHTS ON MOLDING IN THE REAR SPLASH PAN?
    it has a roll pan on it now and the splash pan I had looked like it was beat with a rock. I have it fixed as much as I want to go before I decide if I want to mold it in or bolt it on.
    It's bolted on with three bolts but fits pretty well minus a few spots that need some work to make it fit a little better. This view made me decide to do the 49 chevy front license plate guard.
    Moved it up from the stock location also it has the seams shaved.
  12. DadsBlueFord
    DadsBlueFord
    from Hayden, ID
    Are you going to mold in the front one?
  13. Mr.Dickies
    Mr.Dickies
    Nope not molding in the front one but did shave the two side seams. I had to cut the two ends off bang them out and reweld them on anyways to fix the fit. I do like the look when the front splash pan is molded in but hate the fact that the whole front end has to come off in one piece. I'm a one man show so I have to be able to do things by myself till Tyler gets old enough to help!
  14. DadsBlueFord
    DadsBlueFord
    from Hayden, ID
    I'm kind of a "balance" person. Like if the headlights are frenched, the taillights should be too (or vice versa). I figure if the rear valance is molded in, the front should be too. That said, I'm probably going to be a bit hypocritical in my own build in that I'm cleaning up the trunklid (like you've done) but will probably keep the stainless molding on the hood. Or not. Haven't completely decided on that one yet.
  15. fivefivechevy
    fivefivechevy
    thats some ******** metal flake, and the absolute perfect color of blue, my favorite color (almost the exact color of my car) nice job!
  16. Mr.Dickies
    Mr.Dickies
    I was planning on running the stainless on the front till I saw my car in a B&W picture and kind of think of it like this: the rear is shaved and real smooth,sides are shaved and real smooth then get to the front hood not smooth not shaved except emblem. I am running the 50 Meteor hood ornement that is super nice and feel bad for changing my mind but I just think hood needs to be peaked. I might change my mind about keeping it.
  17. Mr.Dickies
    Mr.Dickies
    55Chevy
    The flake looks best at dusk or full sun. I love the color. The roof is going to be the same flake. I had the paint color matched to the flake so even when you look close you can't see the paint behind it that easy. I hate when you see a flake job and it will have a different color behind it.
  18. Mr.Dickies
    Mr.Dickies
    Polished HAMB tag! and Tyler's head
  19. Mr.Dickies
    Mr.Dickies
    3 inch 45 degree mandrels with 12 inch legs. I bought them a seller on ebay for $18 each.
    Lake pipe cut off.
    Bend cut off and hammered flat where it will meet the fender and rocker
    Flower power mock up.
    inside shape after hammered flat.
    side view
    bottom is cut less than top for angle for fender.
    Tack welded in.
    More welding.
    Front view.
    Rear view.
    Added a piece of metal where pipe is by rocker. Still have to figure out if I'll end it shapewise. either angled or round. Also if I am going to add round bar to end.
  20. BadLuck
    BadLuck
    daaaamn.. awesome work buddy!! glad to see so much progress.. keep at it.. gonna be a beauty!
  21. Mr.Dickies
    Mr.Dickies
    Thank you fine sir! My goal is for mine to be half as nice as your ride!
  22. tikiwagon13
    tikiwagon13
    That is coming along REAL nice, well done!
  23. chaddilac
    chaddilac
    I like them pipes... a bologna slice on the end would look pretty cool with that chrome lake pipe sliding out of it.
  24. EBW
    EBW
    Dude, those came out nice !! I am digging that !
    So... Is that a 51 in the background ???
  25. msalamanca
    msalamanca
  26. msalamanca
    msalamanca
    Here is another cool angle.
  27. msalamanca
    msalamanca
    Also what era/style are you going for?
  28. DadsBlueFord
    DadsBlueFord
    from Hayden, ID
  29. Mr.Dickies
    Mr.Dickies
    P***enger side welded up.
    Rear view
    That one is a 52 Henry J in the back ground
    And this one is a 53 Henry J in the back ground
    I traced the door angle but I don't think I like it.
    Flat looks better to me.
    I tried holding round bar up and I'm just not crazy with round bar with it flat.
  30. Mr.Dickies
    Mr.Dickies
    There was a shoebox coupe built in Detroit around 61-63 that I am going for a loose clone of. My picutres of it got ruined when the ba*****t flooded at my mom's so I have to do it by memory now. It had lake pipes but not molded in and it's was triple lakes but I hate the triples. Thanks for the Ideas!
