Rear Bumper Delete 1948 Fleetmaster
Discussion in 'The Hokey Ass Message Board' started by NextLevel, Feb 11, 2013.
  1. NextLevel
    NextLevel
    I’m thinking about getting rid of the rear bumper and going with a smooth finish in the rear, what do you guys think? Would I have any issues in the long run not running the rear bumper other than protection ?
  2. NextLevel
    NextLevel
    the image is a quick photoshop of what it would look like without the bumper..
  3. pug man
    pug man
    from louisiana
    I think it looks pretty damn good..... Go for it.....
  4. badshifter
    badshifter
    On a stock bodied stock trimmed car its going to look like you just have not put the bumper on. Leaving a part off does not make it a custom. Any other plans to go along with a bumper delete?
  5. NextLevel
    NextLevel
    valid point Badshifter, I didnt think about that.. other plans are to lower the car.
  6. i.rant
    i.rant
    I would also think about how much damage that would result if someone tapped you @ 10 mph. Use the bumper, I agree with Badshifter.
  7. Harrison
    Harrison
    With all that stock trim, it needs a bumper. The bumper will make it look even lower when you drop it too.
    Sent from my DROID device using the TJJ mobile app
  8. NextLevel
    NextLevel
    Burst my bubble!! lol but yeah I see your point. What I dont like about the bumper is it sticks way out from the body, but having all the trim on the car it all ties into the car..
    Your comments really helped! Thanks guys!
  9. 49ratfink
    49ratfink
    I think your car needs a bumper.
  10. sololobo
    sololobo
    Leave it on please!! Nice lookin Chevy bro. ~sololobo~
  11. chaos10meter
    chaos10meter
    from PA.
    Here's a 48 Aero Cp. we are doing, with an old Corvette bumper flipped upside down and molded in.
  12. Can you modify the bumper irons to **** the bumper in closer to the car body?
  13. 325w
    325w
    Wonder how close a ribbed bumper would come to fitting.
  14. Belchfire8
    Belchfire8
    I like that look, but you also need to get rid of at least the trunk lid chrome pieces.
  15. Torchie
    Torchie
    Since you are asking for opinons, here goes.
    For those of us that lived thru the "Street rodder" phase this look brings back memories(Mostly Bad). The only thing worse would be to paint the bumper the same color as the body.
    Plus as has been stated elsewhere that's a whole lot of unprotected ***.
    Look into moving the bumper in closer to the body or just run the bumper with no overrides to help clean up the appearence. Or possibly go with a ribbed Plymouth bumper.
    Post pics of whatever you do.
  16. chinarus
    chinarus
    from Georgia
    You can tuck the bumper up closer to the body without a ton of work.
    Get rid of the overriders and smooth the bumper for a smoother look if you like.
  17. Rocky
    Rocky
    Classified Editor
    Yeah, moving the bumper closer to the body isn't a big deal. When I put my old 50 delivery together I hated the "stick-out" rear bumper. I found a same year Pontiac bumper actually followed the curve of the car's back. Had to remove a 3 inch section from each side of the bumper where it fit into a recess in the car's body. Couldn't afford plating so it stayed body color until I sold the car..
    I built my own bumper brackets and welded the bumper bolts to the back of the bumper to mount it.
  18. mj40's
    mj40's
    Bumpers don't do much good unless they are all at the same height and built like a tank. No this is not the car in the avatar.
  19. HOTRODPRIMER
    HOTRODPRIMER
    Leaving the bumper off is just going to make the car look unfinished,,it's a clean simple car and they look good with bumpers. HRP
  20. historynw
    historynw
    I had a big argument with the shop doing my work , we used the same street rod pan. I made them mark and cut for the bumper brackets. We did have to slightly modify the bumper gravel pan to fit the section where the trunk edge panel meets. I think it makes a 40's car look right with the bumper. You could always use a bumper mount license plate holder from a later model or a wagon.
  21. NextLevel
    NextLevel
    Thanks for the feedback fellas!! I think I'm sticking with a bumper but just bring it closer to the body..
  22. Crusty Chevy
    Crusty Chevy
    And while you are at it **** in the front bumper as well
  23. junkyardjeff
    junkyardjeff
    The damage would probably be much worse if the bumper was not there,with all the idiots on the road today and not many older cars in the junkyards I would never have any vehicle without bumpers.
  24. Chavezk21
    Chavezk21
    I am triming the filler plate between the bumper and body. Bringing in everything. The bumpers both front and rear will be about 1/2" from the body and a little lower to the ground. I seen a '48 sedan done like that in Vegas a few years ago. It looked really good. In the rear since his bumper had been dinged in the center He inset the license plate holder into before he sent it to be rechromed.
  25. rt338b
    rt338b
    from Illinois
    Here is pics done of front and rear bumper ideas. I used chrome moly tubing that fit inside of one another to adjust depth and used bumper guards for nerf bar look on front and flipped rear bumper upside down and ground the clearance to body to fit quarter panels on the rear.
  26. chaos10meter
    chaos10meter
    from PA.
    That looks good.
