ive got a 1952 chevrolet truck with a 230 or a 250, its not the original motor. im trying to turn the motor over by hand but the crank pulley has no bolt to get a wrench on it. how do i go about turning th motor over by hand. also, i belive the motor is stuck, this is why im trying to do it by hand.
A rubber belt strap wrench?? Don't know if you have one around, but, I'd throw mine on the crank pulley and give it a try.
2 bolts in the harmonic balancer where the pully mounts, and a bar between them. Pull the spark plugs out, you should be able to turn it by hand
be patient with trying to free the motor. i have unstuck a few, by squirting loosener fluids [insert your favorite here] and gently prying on the flywheel- every day, once in the morning once before i went home. once it breaks free work it back and forth gently till it makes a full revolution. #6 cylinder is usually the culprit due to the fact condensation runs down the intake toward the back.
i was thinking about what "sunbeam" said, but im thinking about hooking my other truck to it and tugging it. its only become frozen within the past 3 years.
