OK, What is This Thing??
Discussion in 'The Hokey Ass Message Board' started by VoodooTwin, Feb 16, 2013.
  1. VoodooTwin
    VoodooTwin
    from Noo Yawk
  2. GREASER815
    GREASER815
    I never have. Looks kinda cool.
  3. Cerberus
    Cerberus
    I'd have to put that one right up there with ignition noise suppressors.
  4. choppedtudor
    choppedtudor
    It appears to be a 6-volt ballast resistor....
  5. mart3406
    mart3406
    from Canada
    It's an aftermarket ballast resister
    intended to reduce the currant flow
    across the points to reduce arcing
    and extend their life.
    Mart3406
  6. old city
    old city
    Old points would oxidize with higher current going to the points. This device keeps the current constant going to the polnts. tungsten oxide is an electrical oxidization that will turn the points a blue color. They wont have a good contact because they are corroded.
  7. Ebbsspeed
    Ebbsspeed
    The info printed on the back of the box regarding cold weather and low RPM current makes me think this may be more of a "thermistor" than a simple ballast resistor. In any case, it has some low resistance value that lowers the current in the primary side of the ignition circuit. The downside is that there will be a corresponding weaker secondary current available to the spark plugs.
    Bottom line: Do you want points that last longer at the expense of a weaker spark, or do you want to do a little more maintenance of your ignition system and have it operate at it's highest possible efficiency?
    This is a piece that should be on display, not on a car.
