What needs 11/16" wrench?
Discussion in 'The Hokey Ass Message Board' started by XXL__, Feb 17, 2013.
  1. HellsHotRods
    HellsHotRods
    1936 Ford p***enger car headlight mounting main bolt nut is 11/16. It is also a hard nut to find because it is about 3/4" ht and the size is 11/16-18. Just try to find one.
    Also, most tie rod end nuts LH and RH are 11/16.
  2. spark plugs and lug nuts ... not that you would use a wrench on them mainly. Some people argue just to feel their lips move.
  3. davidbistolas
    davidbistolas
    Really? Proove it!
  4. R Pope
    R Pope
    Beats me why 7/16 nuts aren't 5/8" like the bolts. That's the only common size that's like that, unless you're working on certain farm machinery. I think it's Noble that ups the size of all the nuts they make.
  5. Poesrodandcustom
    Poesrodandcustom
    from Kentucky
    A lot of jamb nuts are 11/16 as well as a lot of br*** fittings on glad hand airlines and air brake systems.
  6. go-twichy
    go-twichy
    i'd like to see some pictures of these so-called 11/16" nuts and or bolts. then we should hear from dr.phil or oprah on this for some real answers.
  7. Rattle Trap
    Rattle Trap
    The clutch adjustment lock nut on my Harley is 11/16
  8. Cracker123
    Cracker123
    I used 11/16th wrench or socket on 3 vehicles in the past week; rear bumper of 55 Chevy (7/16th bolt), seat belt bolts on 69 Ford truck (I think they were 7/16 fine thread), and strut rod to lower control arm bolts on 66 Mustang (3/8th bolt with over-size head).
  9. llewellyn
    llewellyn
    If they are working on jap **** 17 mil is the size they would be using.
    Can,t pin point the last time i used a 11/16th spanner (wrench), but it does get used alot on pre 1980s cars in australia
    llewellyn
  10. Poesrodandcustom
    Poesrodandcustom
    from Kentucky
    Cab mounts on a Mack Granite series.
  11. Rem
    Rem
    I was lying under the pickup yesterday, undoing the torque bell nuts, cursing and thinking to myself that there must be a smaller size castle nut to fit 7/16" bolts as these nuts are too close to the bell to get a socket on there, and the mechanical brake gizmo is in the way to get the open ended spanner on there properly.
    And to Willy301, if you're working on metric/import stuff, 11/16" is a (slightly loose) fit for 17mm, for M10 fasteners.
  12. txturbo
    txturbo
    if they haven't used one...they aren't real car guys.
  13. jreeder41
    jreeder41
    Plus they prob have never left there mom's ba*****t.........
  14. 66tintop
    66tintop
    from Canada
    if you own a ford ,you will have a use for one !:rolleyes::rolleyes::rolleyes:
  15. subdajj
    subdajj
    Off your meds again
  16. wex65
    wex65
    from WV
    I have used the 11/16 recently as I remember searching high and low for it a few weeks ago. I think I used it stripping the Model A down.
    Not wanting to sidetrack the thread but you think 11/16 is odd? I was in NAPA the other day asking for a 1" and 61/64 socket. Yes, really, a 1" 61/64. It is the socket required to tighten the steering wheel nut on an old MGA. The guy said that in 25 years he had NEVER sold one. Unsurprisingly, they had to order it!
  17. paintcan54
    paintcan54
    I can't belive I just sat here and read this whole thread about 11/16 wrench. i must get out more.
  18. Rem
    Rem
    At 49.6mm I think I would have plumped for a 50mm socket?
  19. Pretty sure I popped the top on a brew the other day with an 11/16!
  20. Stroker McGurk
    Stroker McGurk
    from Canada
    yepp.....Got those when I inherited my dads tools
  21. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I've got an 11/16 in my toolbox that I had to cut in half years ago in order to install a power steering hose in very tight quarters.
  22. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I know i have a few 11/16 wrenches and sockets
  23. thunderbirdesq
    thunderbirdesq
    Hahaha!:D
  24. All 11/16" wrenches are micro chipped and are in our tool boxes to moniter our activity.
  25. Roger Walling
    Roger Walling
    Ok, it has been proved there is a use for an 11/16" wrench, but what do I do with the
    15/32" wrench that came with my HF wrench set?
  26. Start by keeping it a secret you have a H/F wrench set.;)
  27. rooman
    rooman
    You need an 11/16 12 point to pull the heads of a late model top fuel or funny car.
    Roo
    Contributing to what is basically a mindless thread
  28. Quite a few things on my 60 Belair are 11/16. Never used one much before I got this car.
  29. Or they always pay someone else to do it for them.
    I can't come up with anything off the top of my head but I use an 11/16 wrench all the time.
  30. 57Custom300
    57Custom300
    from Arizona
    Not that you would use a wrench for it but Yblock head bolts are 11/16. Picked up some bulk 7/16 nuts awhile back & they were all 11/16.
