1957 Frod steering column wiring help
Discussion in 'The Hokey Ass Message Board' started by Rolf, Feb 10, 2013.
  1. Rolf
    Rolf
    Hi folks,
    I have this 1957 Ford column that I am using in a project as I like self cancelling blinkers.
    Can anyone tell me what wire is used for what?
    Thanks in advance...
  2. tommy
    tommy
  3. Jalopy Joker
    Jalopy Joker
  4. hellrod666
    hellrod666
    from seattle wa
    Red-input from brake light switch, blue is input from flasher, yellow is left rear sig/stop, white is right front sig there are two greens one is right rear sig/stop the other is left front sig. The rear will light a test light when you put power to the red wire with the switch set for right turn. Hope that helps.
  5. manyolcars
    manyolcars
    Have you ever used "FROD" as a search tern on ebay? Try it
  6. Rolf
    Rolf
    I tried to edit the headline of my initial post but I was not able to.
    My sincere apology to any Frod...ahem, Fjord,...ahem, FORD owner that may had their feeling hurt.
    Also, thanks to hellrod for posting the wire color info. The diagram just shows the wires going in to a connector.
  7. Rolf,I don't think he meant to be insulting in any way.You'd be surprised at how often you can get a good deal because the lister mis-spelled a key word..Good luck on the '57.I have one myself.
  8. Rolf
    Rolf
    Ha, indeed. I was just being a smart ***, so no worries. :D
