What needs 11/16" wrench?
Discussion in 'The Hokey Ass Message Board' started by XXL__, Feb 17, 2013.
  1. J'st Wandering
    J'st Wandering
    11/32 wrench used on Fords somewhere. I think the Model A's. Can not remember where. Or is it on flatheads?
    At least where to use the 11/32 has to make you think. The use of 7/16 inch bolts, therefore the 11/16 wrench for the nuts, is pretty common.
    Neal
  2. Stock SBC motor mounts like from a late '60s car are actually 7/16 and the bolt head is alway they are 11/16 on the nut side as I recall and 5/8 on the bolt head.
    I used 1/16 taking my '53 Stud suspension apart. Some transmission mount bolts are 11/16 as well.
  3. 296 V8
    296 V8
    from Nor~Cal
    These must be the same people that market some of the wrench sets I see for sale that have no 11/16 …………… like the 7/16 fastener doesn’t exist.
  4. Taff
    Taff
    Y block down pipe nuts are 11/16th, I seem to recall
  5. Larry T
    Larry T
  6. hotrawd
    hotrawd
    from lima,ohio
    The real question is "why do they make metric wrenches?". They don't fit anything on my cars.
  7.
  8. chubbie
    chubbie
    I even have a cut off and bent mono use 11/16 wrench i made to put the throttle cable on my 970 case. i've even borrowed it out!! wow that was 30 years ago
    this realy isn't that strange of a tread:rolleyes: most guys don't own a 9/16 wrench and have NEVER needed one:eek:
  9. manyolcars
    manyolcars
    ALMOST EVERY BOLT ON A 8n, 2n AND 9n FORD TRACTOR IS 11/16
  10. billcove
    billcove
    from mass
    x3!
  11. fenderlessA
    fenderlessA
    from canada
    used one to replace the blade on my chop saw yesterday
  12. TagMan
    TagMan
    Best thing about 11/16" wrenches is that when I misplace them I don't miss them as much...
  13. Those guy must just own a tool box to be cool, but hardly use it. How the hell could you be a mechanic for 30 yr and never use one? I used one to remove the wheels on my dirt bike yesturday....
  14. patrick66
    patrick66
    Lots of things require or have 11/16" fasteners. Goofy damn question.
  15. scrappybunch
    scrappybunch
    from nj
    Just checked, mine is as worn as much as the 3/4
    Alot of front suspension uses 11/16..
  16. gassersteve
    gassersteve
    The old Lowey axles on my bicycles were 11/16"
  17. aaggie
    aaggie
    Maybe stealing the thread but I bought a set of Craftsman wrenches back in the early '60s and it included a 19/32" wrench. It still looks new and I have never used it for anything.
  18. jazz1
    jazz1
    the bolts on my bumper are 11/16 head and nut!
  19. Paul B
    Paul B
    Used one yesterday lower ball joint nova clip in my sedan delivery
  20. XXL__
    XXL__
    Thanks, HAMBers, for the references. I think this Internet argument has run its course... until someone googles the mis-information on that other board and represents it as fact-- you know, that 11/16" wrenches were created by a secret government agency to lull us into thinking there were uses for it.
    One guy really nailed the basis of his argument as follows--
    To which, I replied...
    BTW, not only does Craftsman make this wrench for some strange reason, but Stanley is in on the conspiracy as they indicate 11/16" is the standard NUT size for 7/16" SAE here-- http://www.stanleyproto.com/default.asp?TYPE=STATICLEFT&PAGE=charts/chart_23.htm&LEFT=left_cc_01.htm
    Oh well.
  21. 302aod
    302aod
    from Pelham,Tn.
    It takes an 11/16 wrench to remove the plug to put power steering fluid in my M***ey Fergusen.
  22.
  23. Bert Kollar
    Bert Kollar
    Here's four hangin on my board
  24. Mr48chev
    There aren't any 11/16 nuts that I know of. There are plenty of 7/16 nuts that take a 11/16 wrench and that is what he was stating. nuts and bolts are always measured by the size of the shank/thread and not the hex of the bolt or nut. The gent who called you on it is correct.
    Walk into any hardware store of fastener supply and ask for a 11/16 nut or bolt and see the look you get.
  25. junk yard kid
    junk yard kid
    I would be dead in the water without it. In fact i told myself not to buy other sizes untill i get some more 11/16ths ones. Dont see as many at the flee markets.
  26. 50Poopbox
    50Poopbox
    They are all over Large Caterpillar engine's, like 3508's and even a few on smaller ones like 3406's.
    If I remember correctly, the nut that holds my brakeline to the frame on my '59 F100 is an 11/16.
    I believe -10 hydraulic hose's use an 11/16.
    I use them frequently, not always on cars but regardless, you have to be an idiot to say their is no use for them or "That a 11/16 fastner doesn't exist"
  27. propwash
    propwash
    from Las Vegas
    I won a twenty dollar bet once that I couldn't name an American car that used a 19/32" socket. Rod cap nuts on most FE engines. Don't know what else, but that was first time I ever used one (67 GT500)
  28. Olderchild
    Olderchild
    from Ohio
    Throw all them away, then when you need one i'll rent you mine:D
  29. Mike51Merc
    Mike51Merc
    If you throw away all your 11/16" tools you will soon discover everything they're needed for.
  30. 296 V8
    296 V8
    from Nor~Cal
