Short spark plugs
Discussion in 'The Hokey Ass Message Board' started by chuckshomeservices, Feb 18, 2013.
  1. chuckshomeservices
    chuckshomeservices
    from mass
    Stupid question here but does anyone know if they make short spark plug for a chevy 350 small block? I have one that fits so tight against the steering box than in order to pull it I have to lift the engine. I found one from speedway from accell but really want one that I can get off the shelf at the parts store. Any Ideas fellas?
  2. Moedog07
    Moedog07
    These #'s came off line
    Accell #8199 #8197and NGK 2771 plugs are said to be 1/4" shorter than AC Delco R44T.
    Bosch makes platinum short plugs. GOOGLE short SBC spark plugs.
    I've got E-tec heads so I use Champion / NGK small engine plugs (Lawn Mower).
  3. aaggie
    aaggie
    I know the local O'reilly's sells the short Accel plugs and I think Autozone does as well. Years ago I had a '40 Chevy coupe with the same problem and I used a chain saw plug in #5 cylinder.
  4. harleycontracter
    harleycontracter
    I have accell shorties
  5. waltspuffer
    waltspuffer
    Lawn mower plugs, they work great too.....:D
  6. chuckshomeservices
    chuckshomeservices
    from mass
    Bosch plugs ended up being almost a half inch shorter than the delco ones. Perfect fit
    Sent from my DROID device using the TJJ mobile app
  7. Leadsled51
    Leadsled51
    Yep, autozone, o'reillys, advance auto, all sell the Accel header plugs....thats what i run in my 50 chevy with a small block. only ones that will fit with my headers.
