62 Fairlane
Discussion in 'The Hokey Ass Message Board' started by tim03hd, Feb 19, 2013.
  1. tim03hd
    tim03hd
    Hi all,
    I recently acquired a '62 Fairlane with a blown up small block and c-4 ******. I have another 302 on the engine stand ready to go in. I was wondering if anyone knows if I can pull the ****** out with the engine or should I drop it from under the car? It sure looks like a small engine compartment.
    Thanks, Tim
  2. dutch nola
    dutch nola
    you can pull it all at once.
  3. RDAH
    RDAH
    from NL, WI
    You can pull them together if you use one of those engine levelers that adj. the angle of the motor. Harbor Frieght has them. Make sure you drain the trans or put a plug in the tail shaft housing or you'll have a mess.
  4. tim03hd
    tim03hd
    Cool. Thanks. I do have the engine leveler and tailshaft plug.
    This is going to be a Great Ride. Don't see these every day. :)
  5. tim03hd
    tim03hd
    Aint it Cool ?
  6. kenymac
    kenymac
    Just for your information, Your transmission from the 62 will not bolt up to the 302. Ford changed the bell housing to block from 5 bolt to 6 bolt in mid 64. But you may be able to use the ****** if you change to the later bell housing. You should check that out before you try to put it together.
  7. tim03hd
    tim03hd
    It allready has a302 mated to a c-4. Not Original
