Another 235 with open driveline question...
Discussion in 'The Hokey Ass Message Board' started by 54LedSled, Feb 19, 2013.
  1. 54LedSled
    54LedSled
    I am planning on in the future switching to an open driveline in 54' Belair. However I would still like to retain my factory 235. In the near future I plan on adding some headers and dual intake. Its a PG car with 3:55 gears.
    I have a couple questions...
    1) I would like to retain an auto transmission...700r4 or 200r4? Where I'm at it seems like I can pick up a 700r4 alot faster and easier than a 200r4.
    2) Does either transmission allow for the use of the stock speedo cable? I would really like to retain my stock gauges.
    3) Lastly, what rear axle gear ration would work best in my set up? I want to be able to cruise nicely around 70 to 75mph on the highway.
    Looking for ideas or opinions from anyone out there who has or had a similar set up...pro vs. cons...and such
  2. terryble
    terryble
    from canada
    I used a T-5 in my 50 with 261 engine and 205-75R15tires and liked the 3.36 gears best after trying 3.55 and 3.78 first should be the same for either a 700r4 or 2004r although I tended to drive in 4th up to about 60-65.
  3. engine138
    engine138
    from Commack NY
    1- You will need to pick up from Tom langdon a ****** adapter plate
    2- I believe the speedo cable will fit but not 100%
    3- I'm using a rear out of a S-10 blazer 4x4 with 3:42 gears 59.5 inches outside drum to drum fits nice.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    700R4s used mechanical speedometer cables through '90 or '91.
  5. 54LedSled
    54LedSled
    I came across a 55' Chevy Belair rear end, 3.70 gear ratio. Anyone use this with a AOD like a 700r4 behind a 235? Is that a good gear setup?
  6. terryble
    terryble
    from canada
    I don't think you would get much benefit from those gears.
  7. HEATHEN
    HEATHEN
    from SIDNEY, NY
    With a 30 percent overdrive, 3.70 turns into 2.59 in o/d.
  8. Snarl
    Snarl
    You will want to turn around 2200rpms @ 65mph with a 235. Go to an online gear calculator and plug in the numbers. Done.
    both transmissions were available with cable drive. Look before buying.
    '86 and Earlier 700-R4's are not as durable as the later ones, but they can be upgraded. Keep that in mind when buying one.
    Because of the difference in 1st and 5th between the 700-R4 and 200-4R, sometimes one is a better choice than the other. Depends on cam profile and how you plan on using it. A stock 235 will work fine with either one.
  9. 54LedSled
    54LedSled
    Thanks snarl, looks like a 3.70 or a 3.73...would work at a .70, a final .67 on the 200r4 will bring me closer to 70mph @2200. Which is still okay.
    Does the rear axle matter if it came off a manual or auto car? I wouldn't think so, just thought I would ask.
    Again, I am mainly looking to cruise at a decent highway speed, not trying to whoop anyone off the line.
    I am add a 3/4 cam down the road when I have the motor gone through..but for now some headers and maybe a dual carb intake. keep it simple.
  10. fastcar1953
    fastcar1953
    i would look for a 3.42 gear rear end for a manual car or 3.73 for automatic. the rear end does'nt matter if it came out of car or truck ,manual or automatic . it just matters what gear you want.
  11. 325w
    325w
    Start planing ahead for the correct tv cable hook up. It needs to be right. Not sure how you will do that with a pair of carbs on the 253.
  12. 54LedSled
    54LedSled
    325w...educate me...what exactly do you mean? thx
  13. HUSSEY
    HUSSEY
    +1 on this, if you don't have your TV (trottle valve) cable hooked-up correctly and adjusted correctly your ****** will shift all funky and will eventually burn up. In it's simplest form, the TV cable tells the ****** where the throttle is positioned so it knows how to shift.
    When attaching it to your carb linkage you have to be aware the linkage geometry and how far away it's attached from the linkage pivot. Attaching it too close the cable will open slowly and not fully when at WOT (wide open throttle). The reverse is true, if too far away the cable will open too fast and will make the ****** think its at WOT when it may only be 3/4 of the way there. Some internet research and a trip to a juckyard to study the linkage geometery and you'll get it all figured out. Besides, you're going to want to grab some parts such as the mounding braked for the TV cable at the carb end.
    Adjusting the cable it's self is really easy. Check out this link for adjustment along with a much better description of operation and issues when dealing with non-factory linkage.
    http://www.cpttransmission.com/tech_tvcable.htm
    One more thing to think about is the TCC (torque converter clutch) lock-up. You can buy lock-up kits but all you need are a few robbed parts at a junk yard, or just get some fresh ones at the parts store. You can go an even easier route and install a simple toggle switch for the TCC, just don't forget to throw it when comming to a stop.
  14. 54LedSled
    54LedSled
    Thanks for the info Hussey. Unfortunatley I am not that savy...I will probabley have a shop do the whole conversion to open driveline for me. A) I don't nearly have the space I would like to do it myself (living in a cookie cutter home, small garage and crazy HOA). B) i love doing research and figuring out how to build and make things work on my own..but this will be a better task handle by someone with know-how..
    I might set up the rear end myself...but thats about it...
    How about a 350 auto setup, is that worth looking into?
  15. HUSSEY
    HUSSEY
    A 350 doesnt have OD so you wont get that highway speed rpm reduction.
  16. 54LedSled
    54LedSled
    So I am planning on picking up the 3.70 rear end out of that 55' chevy...can I also use the drive shaft out of the 55' as well to mesh to the 700r4?
  17. Snarl
    Snarl
    not as is. The length is probably wrong and the yoke is the wrong spline. It is probably too long, which is beter than too short, just take it to a driveshaft place and have them shorten it and change the yoke and put in new U-joints and balance it.....
    Or leave it till last and let the shop that is doing all the work for you worry about it...
