9" ford rear axle bearing ?
Discussion in 'The Hokey Ass Message Board' started by willie57, Feb 16, 2013.
  1. willie57
    willie57
    from wisconsin
    I'am installing a 9" ford in to my wife's Buick. I got the rear end out of a junk yard so I do not know what year or model it came out of. My problem is finding axle bearings. NAPA can't seem to find the one I need. The rear end is old small ford 2.835 O.D. X 1.378 I.D. X .675 wide. The problem is the width. I can get a bearing same size but the width is .875
    I don't see how the will work. Any help will be greatly appreciated.
  2. fiftyv8
    fiftyv8
    from CO & WA
    How To Recognize 9" Housing Centers
    They do NOT have a removable rear inspection cover.
    '57 - no dimples, flat center band up the center of the rear cover, bottom drain plug.
    '58-‘59 - two dimples on back of housing, flat center band, some had drain holes.
    '60-‘67 – have two dimples, flat center band, oil level hole in back cover.
    '63-‘77 Lincoln, LTD, and Thunderbirds had 9 3/8 inch centers, housings were cut away at the gasket surface for ring gear clearance, one curved rib at the front top portion of differential, strong but poor selection of axle ratiosTypes of 9" Axles
    28 spline axles cannot be shortened and re-splined (they're tapered).
    '72 and earlier 31 spline axles have the ability to be shortened .
    '73 and later 9" (cars) have a 5 X 5 ½ " bolt circle and the axles cannot be shortened .
    '67-‘73 Mustang axles are identified by wheel flange center, with oval hole/recess - 28 splines, with two large holes/recesses and a counter sunk center - 31 splines
    Given a choice of 28 or 31 spine axles, you want the stronger 31spline versions5 X 5 ½ " lug pattern is a "truck" bolt pattern, 5 X 4 ½ " is a "car" bolt pattern.
  3. y-oh-y
    y-oh-y
    can you match the #'s on the old bearings ?
  4. Crystal Blue
    Crystal Blue
    I checked all around the net. It seems there's only one small bearing.
    The only part number I could find is BCARW207CCRA
  5. Olderchild
    Olderchild
    from Ohio
    summit and their pricy as hell
  6. Joe Pass
    Joe Pass
    Is it possible you have an 8in. rear end ?, That bearing matches my 8in.
    MasterPro® Bearing/Seal - Wheel Bearing
    Part # RW207CCRA
    Line: MPB 11.99
  7. That bearing is made by BCA, and the part number is RW207CCRA, go to any bearing supplier or auto parts store and give them the number, they should be able to cross it to the brand that they sell.
  8. havi
    havi
    That was my thought, too. Bottom front third member nuts.... if you can fit a socket on them, it's an 8", if not, it's a 9"
  9. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
  10. Hotrodbuilderny
    Hotrodbuilderny
    Some 8 inch, and
    small bearing 9 inch used the 207 bearing.
    Wheel Bearing - Sealed Type - Rear Wheel
    Part Number: PGB PRW207CCRA
    Product Line: NAPA Proformer Bearing
    IMPORTANT INFO: w/ 8", 9" Ring Gear,Except WFD Axle,w/ Locking Ring,w/ WFD Axle,Sealed Type
  11. fordor41
    fordor41
    207. Go to any industrial bearing supplier.
  12. mgtstumpy
    mgtstumpy
    Does this help?
  13. willie57
    willie57
    from wisconsin
    First thanks for all the help you guys have given me I really appreciate you helping me figure out what happened. Some one years ago installed an 8" bearing and seal into this rear end. Hence the two different bearings and seals. It took a little head scratching to figure the one out but thanks again.
  14. repairmanrod
    repairmanrod
    from colorado
    WTF is WFD?
    Rod
  15. Hotrodbuilderny
    Hotrodbuilderny
    The 3 letter code on the axle tag.
  16. nwbhotrod
    nwbhotrod
    from wash state
    The Beatings look like ther on backwards.
  17. Good Wood
    Good Wood
    from pa
    I had trouble finding them last week. I finally got #88107AR at NAPA.
    Check them out.
