brake line dilema...
Discussion in 'The Hokey Ass Message Board' started by mullskull, Feb 20, 2013.
  1. mullskull
    mullskull
    I'm having a bit of a brake line dilema..
    Here is what i'm building... A full fendered 1930 Model A pick up truck.. 324 olds, t5 trans, 58/59 9".... Stock exhaust... 40 juice brakes up front..the goal is to build the truck within the date range of the engine and rear.. So late 50's... It will.also be my daily driver..
    My dilema is a front brake line issue... I got some great feedback on how to deal with my clearance issue, as well as my game plan to.plumb the truck..
    Basically drill a couple of holes in the frame to run my front brake lines. i marked and drilled the holes to run the lines through...
    The dilema lies in my exicution of said plan... I have a pete &jakes frame mount pedal ***embly.. The rear lines turned out great..i used 3/16 brake line..
    The front i ran 3/16 line out of the master, and to the residual (10lb) valve, and 1/4 line out..I had to do this becouse as you know 40 brakes use 1/4 line... The problem is that the only place to put the t fitting is under the motor mount.. It fits and looks great, but by doing this i will have to run a 90° bend to my brake hose, basically 1/4 line doesnt bend to a tight radius, and it hangs too far down under the frame rail.. It looks.like ****... I tried bending up a 3/16 90°, and its more or less the same thing... There isnt much room to mwork with up there... the frame is boxed to the front cross member... And the motor mount is where it is.. A through frame fittings would work , but no one seems to make a inverted flare fitting that will work with a boxed frame... Or does such a fitting excist?? At this point i think my only viable solution is to run AN from the residual valve through the holes in the frame to through frame fittings(i have some) .. Then accross to other wheel... Going this route all i need is some AN fittings, line, and have my brake hoses made to accept AN, on the frame side...
    I am open to suggestions....so if ya have them lets here em..
    Side note. I want to avoid using a gang of fittings, some of wich i sure dont even excist!
    Nor do i want to drill holes in my frame so i can use the brake hose as its intended to be used(as a bulk head)
    I know problem solving is 99% of building anything... And my lack of experience (first ground up build) didnt give me the forsight to see this coming... part of me feels like im giving up by using AN , the other part feels like ya have to choose your battles...
    I appogize for this long winded post!!!!
    Rich-
  2. BACAGrizz
    BACAGrizz
    Pictures of what you have would be helpful.
  3. HOTRODPRIMER
    HOTRODPRIMER
    Visual aides help. HRP
  4. Willy301
    Willy301
    Here you go,
    Stainless Steel Brakes A0767A - Stainless Steel Brakes Thru Frame Fittings
    <TABLE cl***=itemDetailTable border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD cl***=itemBlockLTop-Blue></TD><TD cl***=itemBlockTop-Blue></TD><TD cl***=itemBlockRTop-Blue></TD></TR><TR><TD cl***=itemBlockLeft-Blue></TD><TD cl***=itemBlock-Blue>Stainless Steel Brakes#884-A0767A
    Long Thru Frame Fitting Kits 2 - 3'' Long Thru Frame Fittings
    2 - 3/16'' Elbows
    2 - 3/16'' Tee Fittings
    </TD><TD cl***=itemBlockRight-Blue></TD></TR><TR><TD cl***=itemBlockLeft-Blue></TD><TD cl***=itemBlock-Blue><FORM id=produc***emForm method=post action=/webapp/wcs/stores/servlet/OrderItemAdd><INPUT value=10001 type=hidden name=storeId> <INPUT value=. type=hidden name=orderId> <INPUT value=-1 type=hidden name=langId> <INPUT value=10002 type=hidden name=catalogId> <INPUT value=false type=hidden name=pricematchvalue> <INPUT value=1 type=hidden name=calculateOrder> <INPUT value=210760 type=hidden name=catEntryId_1> <INPUT value=1 maxLength=2 size=2 name=quan***y>
    $56.99 Ships Today
    <INPUT value=$56.99 type=hidden name=origprice> If you find a lower price on a item we will match it
    The priced matched item includes "to your door" costs
    How to Price Match
    <INPUT style="WIDTH: 350px" id=priceMatchURL value=" Enter item URL or Company Name" maxLength=254 name=priceMatchURL>
    $<INPUT style="WIDTH: 80px" id=pricematch value=" Price" maxLength=8 name=pricematch>
    ****.** Skip Price Match
    <****ON style="BACKGROUND-POSITION: 0px 0px" id=AddtoCart cl***=addtocart ***le="Add Stainless Steel Brakes A0767A - Stainless Steel Brakes Thru Frame Fittings to Cart" type=submit value=""> </****ON>
    Click for JEGS Online Price Match
    </FORM><TD cl***=itemBlockRight-Blue></TD></TR><TR><TD cl***=itemBlockLeft-Blue></TD><TD cl***=itemBlock-Blue>
    </TD><TD cl***=itemBlockRight-Blue></TD></TR><TR><TD cl***=itemBlockLeft-Blue></TD><TD cl***=itemBlock-Blue><TABLE><TBODY><TR><TD></TD><TD vAlign=top></TD></TR></TBODY></TABLE></TD><TD cl***=itemBlockRight-Blue></TD></TR><TR><TD cl***=itemBlockLeft-Blue></TD><TD cl***=itemBlock-Blue><?XML:NAMESPACE PREFIX = FB /><FB:LIKE show_faces="false" layout="****on_count" send="false" href="http://www.jegs.com/i/Stainless-Steel-Brakes/884/A0767A/10002/-1" width="100px"></FB:LIKE><IFRAME style="BORDER-BOTTOM: medium none; BORDER-LEFT: medium none; WIDTH: 100px; HEIGHT: 21px; OVERFLOW: hidden; BORDER-TOP: medium none; BORDER-RIGHT: medium none" src="//www.facebook.com/plugins/like.php?href=http://www.jegs.com/i/Stainless-Steel-Brakes/884/A0767A/10002/-1&send=false&layout=****on_count&width=450&show_faces=false&action=like&colorscheme=light&font&height=21& " frameBorder=0 allowTransparency scrolling=no></IFRAME>
    <IFRAME style="POSITION: static; BORDER-BOTTOM-STYLE: none; BORDER-RIGHT-STYLE: none; MARGIN: 0px; WIDTH: 90px; BORDER-TOP-STYLE: none; HEIGHT: 20px; VISIBILITY: visible; BORDER-LEFT-STYLE: none; TOP: 0px; LEFT: 0px" id=I0_1361396009070 ***le=+1 tabIndex=0 marginHeight=0 src="https://plusone.google.com/_/+1/fast****on?bsv&size=medium&hl=en-US&origin=http%3A%2F%2Fwww.jegs.com&url=http%3A%2F%2Fwww.jegs.com%2Fi%2FStainless-Steel-Brakes%2F884%2FA0767A%2F10002%2F-1&ic=1&jsh=m%3B%2F_%2Fscs%2Fapps-static%2F_%2Fjs%2Fk%3Doz.gapi.en_US.iMghuoRe1IM.O%2Fm%3D__features__%2Fam%3DQQ%2Frt%3Dj%2Fd%3D1%2Frs%3DAItRSTMwv6l3GoOyxFsT2GBmPKRACnLzfg#_methods=onPlusOne%2C_ready%2C_close%2C_open%2C_resizeMe%2C_renderstart%2Concircled%2Conload&id=I0_1361396009070&parent=http%3A%2F%2Fwww.jegs.com&rpctoken=15993630" frameBorder=0 width="100%" allowTransparency name=I0_1361396009070 marginWidth=0 scrolling=no data-gapiattached="true"></IFRAME>
    <IFRAME style="WIDTH: 59px; HEIGHT: 20px" cl***="twitter-share-****on twitter-count-none" ***le="Twitter Tweet ****on" src="http://platform.twitter.com/widgets/tweet_****on.1360972506.html#_=1361396009375&count=none&id=twitter-widget-0&lang=en&original_referer=http%3A%2F%2Fwww.jegs.com%2Fi%2FStainless%2BSteel%2BBrakes%2F884%2FA0767A%2F10002%2F-1&size=m&text=Stainless%20Steel%20Brakes%20A0767A%20Stainless%20Steel%20Brakes%20Thru%20Frame%20Fittings&url=http%3A%2F%2Fwww.jegs.com%2Fi%2FStainless%2BSteel%2BBrakes%2F884%2FA0767A%2F10002%2F-1&via=JEGSPerformance" frameBorder=0 allowTransparency scrolling=no data-twttr-rendered="true"></IFRAME>
    </TD><TD cl***=itemBlockRight-Blue></TD></TR><TR><TD cl***=itemBlockLBottom-Blue></TD><TD cl***=itemBlockBottom-Blue></TD><TD cl***=itemBlockRBottom-Blue></TD></TR></TBODY></TABLE>
    <!-- End DIV "wl-wrap" -->
    I used these, and I thought they were the cat's ***!
    <TABLE width="100%"><TBODY><TR><TD width="33%"></TD><TD width="33%" align=middle></TD><TD width="33%" align=right></TD></TR></TBODY></TABLE>
  5. Willy301
    Willy301
    They offer a couple sizes, and I recommend you get extra fittings with them, they have 2 90 degree and 2 Tee's with them.
  6. mullskull
    mullskull
    I can post some images later...
    But Willy seems to have the answer!!!
    Have you used these before??
    I only ask becouse i have read some stuff about some through frame fittings having issues with holding air bubbles.....
  7. Willy301
    Willy301
    I have bought 3 sets, 2 sets are on my project and work flawlessly, the other set I am going to use for air lines on the same O/T project. No bleeding issues at all.
  8. mullskull
    mullskull
    Excellent... I just orderd a set..
    thanks again Willy!
  9. You could have just run all 3/16", no need for the 1/4"
  10. mullskull
    mullskull
    Tman... originally i was trying to use stock parts, and the brake hoses are 1/4 IF, and to my knowledge (called dorman, and parker) no one makes a reducer bushing to go from 1/4 to 3/16...
    with these through frame fittings i certainly will be running 3/16 the whole way... either way i go i'll need to get brake hoses made up...
    plus i really like the look of of through frame fittings... a much cleaner look than tabs and bulk heads...
  11. mullskull
    mullskull
    that fitting still doesn't solve the issue .... the through frame fitting however does-
    but thanks for p***ing the info along... I checked with Napa as well.. dug through their books.. found nothing.. and that's when i stopped looking.. figure if dorman, parker, and Napa didn't have it no one made it-
    thanks-
  12. mullskull
    mullskull
    here are some photo's... yes it's after the fact, but perhaps they will help someone else..
    the first is a photo of the area mentioned... with a 1/4 line..
    the second photo is where the through frame fitting will live, basically right
    where the front bolt for the original lever shock is -
    thanks for all of your help guys..
  13. dondogarage
    dondogarage
    from richmond
    I seen a thread on soft brake line kit 25' I think they were maybe grenish color, search, didnt find it. any idea THANKS
