Rear end suspension set-up for 55 chevy with nine inch?
Discussion in 'The Hokey Ass Message Board' started by Jay Tyrrell, Feb 20, 2013.
  1. Jay Tyrrell
    Jay Tyrrell
    Hi,
    Well this year I thought I should take a look at reducing the wheel hop that I am getting under hard launch in the 55 chevy. My current set-up is a nine inch rear end with the leaf springs in the stock location.
    The frame is actually a 1956 and the only thing that I have done so far to the rear suspension is added new Energy Suspension bushings to a new set of 1956 shackles and hardware and that is it.
    I am looking for a simple and inexpensive fix. This car definately over the last couple years has seen more street duty then strip and that is what I predict it will be for a long time to come.
    So what do you suggest? What are some options that will eliminate and or lessen my wheel hop?
    Thanks
    Jay
  2. GassersGarage
    GassersGarage
    Cal Trac bars. The '55 in my avatar had old ******* bars which rode well but also controlled wheel-hop. I was running the stock '55 rear end with a 4:56 and posi.
  3. rustang
    rustang
    +1 on the CalTracs
  4. john mullen
    john mullen
    The old skool way we did it was to weld two tabs about 3 inchs long to the u bolt pad under the spring with 1/2 in holes in each then add a 1.1/4 peace of pipe about 30 inches long with 1/2 in boles drilled in each end weld 2 more tabs under the frame foward on the frame for the front holes and bolt it in .cheeep but very effective...garenteed to stop wheel hop and it looks old skool too. I had them on my 55 chevy with a pontiac 389 with trips and 4 speed and olds rear.....bullet proof
  5. black 62
    black 62
    from arkansas
    clamp the front 1/2 of your springs...
    AHotRod likes this.
  6. Chevy55
    Chevy55
    from Nebraska
    A pair of old school ******* bars got my brothers 55 into the high 11's years ago. Just fine tune the distance between the snubber and the spring eye until you like how it works.
  7. 55chieftain
    55chieftain
    Whats you pinion angle like? You could probably get by with having the rear lower 1/2 to 1 degree. Traction-Masters would probably help also. As for mine, i'm clamping the front springs to act more like a control arm than springs. I added in extra springs so spring wrap up is more difficult to happen.
    http://www.tractionmaster.com/index.html
    edit :dang you guys type fast
  8. Hotrodbuilderny
    Hotrodbuilderny
    Good old fashioned ******* bars. Just make sure they are long enough to hit the eye of the spring.
  9. DO NOT go with ladder bars, I agree on the Cal-tracs.
  10. Larry T
    Larry T
    ******* bars are about as traditional as you can get for the 60's/70's.
    And I guess you can make them work OK.
  11. black 62
    black 62
    from arkansas
    first ******* bars i saw were on a camaro ---are they older than that ? i have never cared for the looks of ******* bars---spring to frame traction bars will control wheel hop they will not plant your tires---your pinion must rotate (angle change) to do that---that is why cal-tracs work---easy and cheap to make your own if you think it thru...
  12. Hotrodbuilderny
    Hotrodbuilderny
    What?
  13. Jay Tyrrell
    Jay Tyrrell
    Interesting! Does anyone have the instructions for mounting the Caltrac style ones? I do like the look of them. The old ******* bar style is good too??? I think I need to do some more research on this one before jumping on one or the other.
    Jay
  14. Hotrodbuilderny
    Hotrodbuilderny
    I have a friend who has Caltrac bars on his 55 and seems to like them, that being said they sure aren't period correct, and ******* bars work just fine as shown in the picture above and they work equally as well on 55's I will be using them on my 55 with a 427 4 speed.******* bars that is.Since you are looking to stop wheel hop, ******* bars will be more than enough.
  15. Bad Banana
    Bad Banana
    Get a good set of shocks. Stock spring and home made traction bars on my junk. It worked perfect the minute I put the right shocks on it. Period. ;)
    Go to you tube and study the videos.
  16. lht
    lht
    budget ******* bars caltrac if you got the cash both will work but *******s look cheesy to me
  17. Have some plans that we used to make 2 sets of caltrac clones with. Found through a google search a while back. PM me your email, and I'll forward the doc file I have on them.
  18. Jay Tyrrell
    Jay Tyrrell
    Well I am still just looking at all my options at this point. I actually did call Catrac to ask some questions. People have said that these guys are super helpful and very knowledgable. They definately seemed to know there **** and were really helpful. Still going to do some research on the ******* bars to see what is up with them.
    Shockwise right now on the rear end I am running air shocks but I was thinking of different options here too. Any ideas? Keep in mind that this car sees more street duty.
    Jay
    Jay
  19. Jay Tyrrell
    Jay Tyrrell
    Do you have any still shots showing the rear end set up Banana?
    Jay
  20. dblgun
    dblgun
    Had a pair of Calverts split mono leafs and CalTrac bars on my 55[​IMG] 210, they worked great. Not a 100% old school look but probably the best setup going for ease of use and function.
    AHotRod likes this.
  21. Bad Banana
    Bad Banana
    I wouldn't recommend this set up for the street. If I were you I would make my own ******* bars from the lower shock mount (or look for an old set on CL or EBAY) and spend your money on the Caltrac single adjustable shocks. You need brackets on the frame and forget mounting the shocks on the body like stock. With air shocks, the body is likely cracked already around the shock mounts. The springs hold up the car, not the shocks. ;)
    I used 2000 S-10 rear shocks as a template and made brackets to fit the "T" style shock and welded the brackets to the inside of the frame (not shown in this pic). Called Caltrac and gave them the measurements and they sent me ones to fit. You don't need double adjustable and you can then have a "street" and "race" suspension set up just by turning a knob and it will work fine in both worlds.
    Wheel-hop is uncontrolled spring and tire bounce. The shocks job is to control the springs and tires. Without the right shock, any other mechanical band-aid that anyone claims is a fix is more likely inducing bind to stop the wheel-hop. Induced bind will not plant the tires and launch the car the way you want it. Plus any "adjustments" will not be effective.
    AHotRod likes this.
  22. Jay Tyrrell
    Jay Tyrrell
    Hey man this is some good info! The tops of the rear shocks have long been in a crossmember that goes across the frame rails. So that problem can be checked off the list. Having shocks mounted to the floor of the trunk is a big No No for street and strip abuse for sure. Tell me more about these shocks are you recommending the single adjustment shocks or double adjustment ones Banana? I'm not really clear on which ones I should be looking at?
    Jay
  23. Jay Tyrrell
    Jay Tyrrell
    Were you using this car on the street with this set up?
    Jay
  24. dblgun
    dblgun
    80/20 street/strip, worked well on the street once I got it setup. Changed out the springs segments once with Calvert. Once I got that done it was all good.
  25. black 62
    black 62
    from arkansas
    spring wrap is your problem---don't over think it...
  26. Bad Banana
    Bad Banana
  27. Moedog07
    Moedog07
    I think the early Shelby Mustangs had Caltracs or Traction Masters as an option, so that would have put them in use '65 or '66.
  28. Hotrodbuilderny
    Hotrodbuilderny
    No they ran a Traction master bar which is not the same as a Caltrac, other than they both used round tubing.Caltrac allows for a pivot in the front Traction masters clamped the front spring.Even if they were the original post was for a cheap way to stop wheel hop.******* bars will be much cheaper than Caltracs as I said a friend of mine is running them on his 55 and my brother in law ran them on his slightly off topic 67 Camaro and both were happy with them.I am not knocking Caltracs,but the cheapest answer would be ******* bars and they work fine.I have built 4 link race cars, ladder bar race cars ,and ******* bar race cars.Look at the picture of Jenkins car in this post (post 10) he is using ******* bars. What is wrong with them?
  29. black 62
    black 62
    from arkansas
    were ******* bars around before 1967 ? we all know they can work but they look funny---when were they first used ?
  30. slacker1965
    slacker1965
    I run homemade *******s on my 55 w/9"...I moved my springs under the frame for tire clearance.... the *******s hit the spring under the eye .... used s**** tubing & plate cost nothing... for the ft pads I used free salvage yard pinion snubbers.... I did make a shock xmember out of s**** angle & 1x1 tubing
    I guess they were free if you don't count your time....
    the car leaves good, but I am not running slicks on the strip....
    *******s do nothing for bite, just keep the spring from wrapping up.....
    hope this helps
    email slacker1965@juno.com if you want me to take a pic or 2.....I did this in '85 so it's not real pretty under there
