Projects Carb rebuild
Discussion in 'The Hokey Ass Message Board' started by cornbinder52, Jan 9, 2013.
  1. cornbinder52
    cornbinder52
    It may seem like a very simple thing, but since the cold hit here in Illinois I have not been doing much on the car. Since I got it, you have to choke it to get it started, but it will not run on less than 3/4 choke. I checked the idle screw and it was turned out six turns! I reset the screw and started ****ing with the idle speed. I got it to run about half choke. Turns out after pulling apart the carb the float adjustment is off by quite a bit and there was all sorts of **** in the carb. When u went to check the filter (sediment bowl on top of pump) the po had used rtv to seal the gl*** bowl down. It disintegrated and plugged the fuel pump rather well, not to mention that the br*** screen has several holes in it. New one on its way. Anyway, I thought I'd share a pic or two of the carb. Since I am waiting on the pump I got out the dremel for a few hours last night. What do you think?
    Before
    After. It's not perfect, but I like it!
  2. looks great nice polish job
  3. cornbinder52
    cornbinder52
    Thanks. I tore down the carb to clean it and waited two days for the kit to arrive, and I haven't been sleeping well for a few months, so I thought I would do something productive that cost nothing. It needs some attention, but it looks better than it did.
  4. nali
    nali
    One looks nice once polished.
    What about 3 ? :)
  5. cornbinder52
    cornbinder52
    Jealous! That's step number two. Or three. I was wondering if the manual choke carbs will be a problem with a multi setup. I imagine I will have to fabricate linkage for the choke. I hope to find one already set up. Carbs are my nemesis. They are simple to understand, they just usually kick my ****.
  6. cornbinder52
    cornbinder52
    So my polish job quickly turned to a hazy gray. What are you all using to keep your carbs and such shiny?
  7. radconjon
    radconjon
    Yarns ago when I played with OT imports I would hit the polished AL with clear lacquer.
    Kept it shiny for awhile.
    Jon
  8. fast30coupe
    fast30coupe
    from Illinois
    X2 on the clear
  9. cornbinder52
    cornbinder52
    Will a rattle can lacquer work well? Just don't want to busy out the gun for small parts.
  10. lht
    lht
    its hard to find but gl*** wax works great on polished aluminum pink lookin stuff repels water good too, use it on my harley stuff as long as you keep a coat on their once in awile you won't have to re polish
  11. radconjon
    radconjon
    I always used a rattle can. I do some woodworking and am amazed at what you can do on small jobs with a rattle can.
  12. nali
    nali
    I ve used Eastwood Diamond Clear.
    It seams ok for now. It resists to heat and fuel.
    The pb is it s very liquid and I found it hard to apply.
