HELP!!!! Installing 90 degree boots on to spark plug wires
Discussion in 'The Hokey Ass Message Board' started by bp1971, Feb 21, 2013.
  1. bp1971
    bp1971
    from Fresno, CA
    Please help...are there any tricks to installing the 90 degree boots on to the spark plug wires. I am extremely frustrated with this process.
  2. hotroddon
    hotroddon
    WD40 and patience are your friends
  3. Okatoma cruiser
    Okatoma cruiser
    from Ms
    Go-Jo hand cleaner-(non pumice) works good too
  4. Joliet Jake
    Joliet Jake
    from Jax, FL
    A good lube and needle nose pliers has always worked for me. As with any exercise in proper penetration, make sure everything is well lubed prior to insertion! 0.0
  5. 61 chevy
    61 chevy
    just a little squirt, all its takes :D
  6. bp1971
    bp1971
    from Fresno, CA
    Thanks guys.
  7. every thing stated as above ................cold beer and a trusted buddy , misery loves company (and then there's only half as many for you to do)" Ideal " makes a wire pulling lube that works great , we call it wire snot in the industry.
  8. tedley
    tedley
    from canada
    You can use hair conditioner to if your wife doesn't mind. Slippery schit.
  9. tudorkeith
    tudorkeith
    also have the boots good and warm. I usually set mine on the hood on a summer day until I use them well lubed. I prefer a little silicon spray or wd-40 but many things work. Hell just spit on it.
  10. Raven53
    Raven53
    from Irwin Pa
    Silicone spray wont degrade the rubber and makes them really slick for pushing through.
  11. GREASER815
    GREASER815
    I use silicone spray too. Always worked for me, just take your time and be careful.
  12. skicker
    skicker
    from Gone
    Use silicon spray, slide the boot on first twisting it while you slide it on a couple inches past the end. Cut the wire and add the 90 degree metal end, them slide the boot down over it. Twisting it gets it through the boot easier.
  13. side_valve
    side_valve
    Alliance Vendor
    Soak the boots in HOT soapy water
  14. iammarvin
    iammarvin
    from Tulare, Ca
    Just a squirt of the wife's dish soap. Slides like a sloppy *****mon.
  15. SinisterCustom
    SinisterCustom
    Hahaha...I just made my plug wires 30 minutes ago....
    I just put all the 90* boots in warm, soapy water then slide 'em on...less messy than WD-40. I then strip the wire and crimp the end on...
  16. supervert
    supervert
    i just did a set last week, i used some spray silly-cone and plain wire crimpers. but i have just bought some real plugwire crimpers because i went to pull one of to change the cap and the damn thing came apart. i just couldn't get a good crimp on them.
  17. hombres ruin
    hombres ruin
    A lot of aggressive swearing and kicking of **** works for me
  18. gnichols
    gnichols
    from Tampa, FL
    A buddy uses the spray silicone but pushes a large Phillips screw driver thru them first in order to coax them to "straighten out a little while" before inserting the wire. But I think the hot soapy water trick sounds even better as it would soften-up the whole boot. Gary
  19. BillM
    BillM
    I ground down an old screwdriver to help push the terminal and wire through the boot lubed with WD40.
  20. 4woody
    4woody
    You are putting the boot on the wire before crimping on the terminal...Right??
  21. junk yard kid
    junk yard kid
    Actually I used brake part ***embly lube when I made yours.
  22. da34guy
    da34guy
    Dielectric grease on the inside of the boot and a little on the wire and it'll push right thru.
    Takes about 5 minutes to do a full set.
    No silly cone or wd 40 mess
  23. 60 Belair
    60 Belair
    Plastic wire tie on the wire itself and soapy water, pull it thru with wire tie.
    Andy
  24. 56FRLN
    56FRLN
  25. I spit on em, and use a philips screw driver from the sparkplug side to ade them along if nessasary.
  26. oldsrocket
    oldsrocket
    I use this type of bent needle nose plier. You can get them around the bend to pull them through before putting the end on. I use dielectric grease, but the silicon spray sounds like a good idea too. Will have to try that next time.
  27. bp1971
    bp1971
    from Fresno, CA
    Awesome advice!!!! Thanks again.
  28. bp1971
    bp1971
    from Fresno, CA
    I ended up using some silicon based grease and it worked like a charm. I had the whole set done in under an hour. Thanks again guys for your help.
