v8 60 tin side
Discussion in 'The Hokey Ass Message Board' started by janbuick, Feb 21, 2013.
  1. janbuick
    janbuick
    I have a tin side v8 60
    can somebody tell me if this engine is made in the usa or in europe
    perhaps the numbers can tell
  2. janbuick
    janbuick
    bttt
    somebody has to know this
    please help
    I found it in a yard in belgium
    jan
  3. 117harv
    117harv
    V8 60...what year is it? Here is a thread with some info that may answer your question. There are several to be had with the search function (***les)
  4. janbuick
    janbuick
  5. alchemy
    alchemy
    Tin sides were only made in 1937. As for the numbers cast in the bellhousing, maybe if you showed a pic that wasn't half shadow you might get some answers. But probably not since the meaning of most of the code numbers on a flathead bellhousing are unknown to anybody but the factory worker.
  6. ventilo
    ventilo
    I guess that's only true for the North-American engines. The French didn't follow that rule.
    Is the engine out of the upstairs floor in the old shed in Chatillon? Then I ***ume French Vedette origins. There were plenty of tin-side V8s laying around on the floor:
    http://www.fomcc.de/gallery/schrott/2008/schrott2008.html
  7. janbuick
    janbuick
    I dont think its ford vedette
    they used the later version from the v8 60
  8. janbuick
    janbuick
    some more pictures
  9. Bruce Lancaster
    Bruce Lancaster
    Most European Ford blocks have the serial stamped on them, whether US made or made over there. SOME early serial numbers would exclude USA Market ones, even though those engines were actually built here.
    Is there a number on manifold surface of block?
  10. janbuick
    janbuick
    no there is nothing stamped on the intake surface
  11. Dr. Frankensickle
    Dr. Frankensickle
    from Kansas
    I might be of a little help,you see in the tin side block was 37 only,also the waterpumps for 37 only had a taper seat where they screw into the front cover,if your front cover has not been changed,you should have tapered waterpump seats,hope this helps.
  12. Dr. Frankensickle
    Dr. Frankensickle
    from Kansas
    Plus I believe the foriegn versions were using a type of regular distributor and were metric threaded bolts as well.try screwing nuts on the head studs and see.I'm will to say its USA made 1937 v8 60hp
  13. janbuick
    janbuick
    the treats are not metric
    I have tested that
  14. Dr. Frankensickle
    Dr. Frankensickle
    from Kansas
    google it then hit images that will help identify your motor I think.
  15. Bruce Lancaster
    Bruce Lancaster
    A problem on ID is that v860 went into production during 1935 and was sold into Europe via England for almost 3 years before they tried them here...I think probably all the first several years were US produced and shipped to England and Europe, then French Ford was Sold off and 60 production with significant mods started over there.
    Ford England produced a complete car (model 62) for the 60 engine, differing from the regular USA models, and this became the basis for matFord and some German cars. The furrin variants like vertial distributor and such started after a few years of regular Ford stuff.
  16. janbuick
    janbuick
    thanks for the replies
    so you say that my engine is built between 1935 and april 1937
    because it was found in belgium
    am I correct ???
  17. janbuick
    janbuick
    I foud a number on the intake surface
    after cleaning it
    it reads
    *54*146591
    sorry for the blurry pic
    thanks
    jan
  18. ventilo
    ventilo
  19. alchemy
    alchemy
  20. Bruce Lancaster
    Bruce Lancaster
    It then is a USA built engine, as all from beginning in 1935 were US built until later than that, but I do not know when England or Europe started actual production of 60 motors either as Ford or for the later French variants. The car it was in could have been either an American '37 or a British ***embled US/Canada style Ford or a British Model 62...
    I think it becomes harder to tell in Holland or the Scandinavian countries because they could buy cars from any source. The bigger countries had tax systems that discouraged many possibilities.
  21. janbuick
    janbuick
    does the exhaust manifolds say something about the origin ?
    thanks again
    jan
  22. Bruce Lancaster
    Bruce Lancaster
    The exhausts look right for USA car. I have seen different ones on pictures of foreign 60's but have no idea what sort of ch***is they came out of.
