Where have you mounted your Tach? Kustoms and Hot Rods
Discussion in 'The Hokey Ass Message Board' started by zep058, Feb 20, 2013.
  1. Steves32
    Steves32
    from So Cal
    Gotta ask-
    Why a tach in a kustom?
  2. No reason a beautiful car can't have a hot powerplant!
    ...and as we have seen in earlier posts, it can be done VERY stylishly!
  3. EZ Cool
    EZ Cool
    Alliance Vendor
    from Slaton TX
    There's no tack on that tick tock
    here's a tick tock tach
  4. saltflats
    saltflats
    from Missouri
    You folks need to look closer and read my first post.
    **** it worked fooled you.
  5. I mounted a sun tach on the column of my floor shift 75 cutl*** back when I was young.
    It fit nicely in the right gauge pod where the clock was. Being very excited to see it work, I backed it out of the driveway, threw it in low, and labeled the gas.
    But the tach was gone!!! Wtf????
    I threw it in park and it magically appeared....
    This was when I learned that floor shift cars were still connected to the steering column so that the neutral safety switch would still work...
  6. Gator
    Gator
    from Statham Ga
    Moon tach on the column of my '55 - simple 'old school' radiator clamp mount. ;)
  7. Canuck
    Canuck
    Outside corner under the dash in my 30 Coupe. Dash is 34 Chevy Master. Bracket is home made.
    Canuck
      80.8 KB
  8. primed34
    primed34
    On the column in my '55. Didn't want to drill holes in my dash, but tachs looker cooler on the dash.
  9. chubbie
    chubbie
    FLAWLESS!!! 100% perfection any questions??? any one?
  10. old buzz
    old buzz
    from middle tn
    On the dash where it belongs!
      321.3 KB
  11. iammarvin
    iammarvin
    from Tulare, Ca
    My boat steering column needs some help, thought this thread may help me. Wanna mount the speedo and tach in this column mount. How would I drill out this chrome peace?
  12. KUSTOM 50
    KUSTOM 50
    Made a bracket to mount above console
  13. vetrod62
    vetrod62
    Hot rodding this 62 vette for 46 years. Dash replacement is really expensive. Pad.. $300+, labor to remove the windshield, instrument cluster, P*** side trim, over a $1000. Who would be dumb enough to destroy such an expensive installation?? I guess me.
    Where do you mount the tach?? On the new dash of course, It is the highest part you can see while running the gears down the track. Screw the purists.
    I guess the answer is up as high as you can.
    And for some practical application.
    http://www.youtube.com/watch?v=0iKfIrZd2I8
