Projects The Kustom Falcon
Discussion in 'The Hokey Ass Message Board' started by Kustom.Falcon, Sep 13, 2012.
  1. Royalshifter
    Royalshifter
    Moderator
    He was at the Victoria harr***ing me and the lady...ha ha.
  2. Kustom.Falcon
    Kustom.Falcon
  3. Kustom.Falcon
    Kustom.Falcon
    Slowly but surely. Got the Wilwood rear calipers last night and did a clearance check on a spare set of Supremes. Looks like I'm in business. Supposed to receive the fronts and some break line tonight.
    Kustom Falcon Build Thread:
    http://www.jalopyjournal.com/forum/showthread.php?t=734282
  4. Kustom.Falcon
    Kustom.Falcon
    Trying to decide weather or not I buy the original wiring kit - easily over $600 just in wire - or go with an aftermarket kit and hope I'm smart enough to wire this bird on my own. Time to crack down expenses.
  5. need louvers ?
    need louvers ?
    If I may... Go wiht an aftermarket Street rod type kit. Our little cars are a ton of fun but in my opinion come with the hinkeiest wiring sytem this side of a '68 VW. Stock the headlight switches don't last real long, and there is only one or two fuses in the whole deal. You can do better!
  6. Kustom.Falcon
    Kustom.Falcon
    Louvres, I'm with you. Then comes the age-old "who makes a better..." question that I'm watching on other threads. Painless uses Ford color coding, which I like, as trivial as it is, but they're pricey. Rebel is a good deal if you know what you're doing, which I don't. Yet.
  7. Kustom.Falcon
    Kustom.Falcon
    Working on the windows. I've got some cerium oxide, and hand polished the gl***.
    The frame screws are stuck, so I threw a smattering of WD-40 on the screws. I ruined two hand screwdrivers trying to get them loose.
  8. ClearSpot
    ClearSpot
    from Michigan
    Try repeatedly soaking those screws with PB Blaster.You can find it almost any parts store.Works better than Wd40 I've found.
    Where did you buy cerium oxide?
  9. Kustom.Falcon
    Kustom.Falcon
  10. need louvers ?
    need louvers ?
  11. Kustom.Falcon
    Kustom.Falcon
    It's great stuff but pricey. It's very, very similar to "jeweler's rouge," but without the terrible staining properties. I got mine from a local gemologist/jeweler, but you can get it in tubs online. Check Amazon. It's really easy to use. The jeweler suggested I get a large piece of felt and cut out a pad for a real slow buffer, and buff the gl*** out with the felt and Cerium oxide. Also, use a gl*** polish/wax when you're finished to protect the new layer of gl***.
  12. Bigcheese327
    Bigcheese327
    Amazon lists it through a place called "Showerdoorsdirect" - so maybe your friendly local kitchen-and-bath contractor?
  13. Kustom.Falcon
    Kustom.Falcon
  14. Kustom.Falcon
    Kustom.Falcon
    Trans mount is finished - thanks to Derrek and Jarod at Boling Brothers, and had them order a 16-circuit Rebel Wire kit. Hopefully I can get my new front and rear calipers mounted this weekend. I got a spray can of POR-15 ch***is black to try on some parts like the caliper mounts.
    Work has been getting in the way of important stuff like my 6 month old boy, and the Falcon. Unfortunately, it's not going to slow down in the foreseeable future, so I'll be cramming work into the Falcon when I can.
  15. Kustom.Falcon
    Kustom.Falcon
  16. Kustom.Falcon
    Kustom.Falcon
  17. Kustom.Falcon
    Kustom.Falcon
  18. Kustom.Falcon
    Kustom.Falcon
  19. gecko54
    gecko54
    from Sumner, WA
    You may be getting tired of the compliments but I really like what your pulling off here. Boulevard cruiser meets Hot Rod done with higher end components yet keeping it in the real world of the backyard builder. Great vision and execution sir.
  20. Kustom.Falcon
    Kustom.Falcon
    I will never tire of the compliments. I'm a hot rod and Kustom nerd. While other people chase sports stars and celebrities, I stutter and blubber like a little kid when I meet guys like Steve Stanford and Thom Taylor. So when real, true to life car guys have nice things to say about my vision and taste, it's truly an honor. Thank you!
  21. 117harv
    117harv
    ^^^ Well said...really enjoying your build:)
  22. Kustom.Falcon
    Kustom.Falcon
  23. Subscribed. Great inspiration to get me back on my build. Real excited to see this thing live!
  24. studeynut
    studeynut
    Just last week I read on the HAMB about 50/50 mixof trans fruid and acitone, I tried it, seemed to work great so far.
  25. Kustom.Falcon
    Kustom.Falcon
    Little by little.
    Cleaning up the front end for final ***embly. A couple cans of POR-15 Ch***is black, some vaseline to protect joints from overpay, and some elbow grease. Working on a break issue where there's virtually zero clearance between pads and the rotor.
  26. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Dude, the Falcon is lookin' good.
    This can is available at yer' local GM type store:
    I'm too lazy to mix anything up...
    It's never failed me....
  27. Kustom.Falcon
    Kustom.Falcon
  28. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    I dunno' what your tryin' to do but I've had success with this, too:
    Kinda' pricey though....
  29. rocko112869
    rocko112869
    from N.Y.
    Awesome Falcon! what size wheels are they front and back? 15x?-front and 15x? reversed-back and what size are the tires?
  30. Kustom.Falcon
    Kustom.Falcon
    Hey thanks! Working out some issues with my front brake setup right now.
    Front: 15x6 standard, rear: 15x7 reverse
