Projects Monster in the Making
Discussion in 'The Hokey Ass Message Board' started by riceman, May 6, 2010.
  1. Pete1
    Pete1
    from Wa.
    Does the blower drive have change gears???
  2. riceman
    riceman
    This type of Potvin drive is made so the secondary gears are can be changed to overdrive the blower more. Potvin Doug had a coupler spline drive off the double keyed crank made. Very simular to a dragster driveline coupler.
  3. riceman
    riceman
    With the blower sitting in the front, I asked Potvin Doug how he times the advance on his Magneto ? He has the flywheel marked up to TDC to 50 degrees BTDC. Doug also rotates the motor with a bump starter switch or by moving the flywheel with a wrench on the torque converter bolts. No thanks.
  4. riceman
    riceman
    The 331 triple nickel heads are on ! Triple valve spring, ***aium retainers with large locks, ported, stainless valves, O-ringed, steel guides. the rockers are a combination from Rocker Arm Specialites and with John Dearmore Roller Rockers for the exhaust side. Black fuel fittings and Earls black lines for the fuel system next !
    Deuces likes this.
  5. riceman
    riceman
    Potvin Dug and Leavin Lori Peterson are getting closer to firing it up. New 331 triple nickel heads on their 392, new roller lifters from Crower, Smith Bros. push rods and their new rocker arm set up. The rocker arm set up has stock stands, hard chrome shafts with adjustable intake rockers and Dearmore Racing Ent. adjustable aluminum roller rockers. Due to the 240lbs. of seat pressure, the long length of the exhaust arms and roller cam lift ramp, the weak link are the stock exhaust arms. The stock oiling system for the rocker arms are maintained. The arms bronze bushings are groove at the oiling holes in the shafts. John Dearmore's builds rocker arm ***emblies for all application from street to Nascar trucks to 800 cu. in. Mountain Motors, 10,300 rpm nostilgia Top Fuel motors that have ran 5.60 @ 260 mph with 400 lbs of seat pressure. The fuel system is plumbed, throttle and fuel pump shutoff are all done. No Zoomies for this monster, it's Weedburners headers ! The motor was spun for oil pressure with 50wt Valvoline racing oil at 75 lbs of pressure. Plans are to fire it real soon so stay tuned.
  6. Zig Zag Wanderer
    Zig Zag Wanderer
    great thread! subscribed
  7. riceman
    riceman
    Doug Peterson with his daughter driving is living proof ,dreams come true. Today at Sacramento Drag Strip, at 3:30 pm, on Alcohol fuel only made a p*** that was amazing for their Potvin blower 392, early 1700 lbs 1960s style dragster. Lori left the line at idle, high gear only, 1.50 sixty foot, 7.002 at 1000 ft, shutof...f at 1100 ft and ran a 8.09 e.t. @ 176 mph. I would say there is a 7.70 in that dragster ! SO COOL
  8. KING CHASSIS
    KING CHASSIS
    Super Bad. This car is always talked about by me to my friends. Good job.
  9. Mazooma1
    Mazooma1
    alcohol only and that fast?
    unreal.....what a machine!!!!!!!!!!
  10. riceman
    riceman
    Potvin Doug Peterson is putting new rods, pistons, rings and bearings in. The Powerglide two speed has been gone over with a trans brake for high gear. A full set of John Dearmore DRE Roller Rocker Arms are going in the heads.
    The old block with over 150 p***es on it ran 8.09....LOOK OUT 7.50 !
  11. Deuces
    Deuces
    Hey Riceman! What's the latest on this beauty??? :)
  12. Deuces
    Deuces
  13. riceman
    riceman
    Sometimes plans go the wrong way. With the new long block, more compression, new trans with a working trans brake and a 3:54 rearend ratio doug and Lori went to Sacramento for testing p***es.
    The higher rearend ratio didn't work out as planned. The wheel speed at the launch was too slow. It bogged, but after 1/2 track it hauled the mail. The ilde rpm was raised and the barrel valve was fattened up 2 flats.
    Lori came out of the burnout box really hard smoking the M & H slicks. Left at an idle in high gear and rolled into the throttle hard, got sideways, drove through it never lifting and clicked it at 1200 ft. 8:34 et at 178 mph.
    Doug and Lori are taking baby steps. The motor seem fine, but they will put in the 3:90 ratio back in after Kingdon Drags this weekend.
    The Peterson's want to run in the 7:60 cl*** and it will get there. Just remember Lori hasn't left in low gear yet with rpms up, the trans brake on and drive it all the way through yet.
  14. riceman
    riceman
    Here they at Sacramento with a new Speed Sport injector scoop. Steve Justice photo
  15. Deuces
    Deuces
    Cool! Keep us posted!! Thanks... :)
  16. Deuces
    Deuces
    Feel free to post more pictures of that motor if you have any.... Thanks in advance!! :)
  17. riceman
    riceman
    6 psi in the slicks and about 10 feet off the line. Steve Justice photo.
  18. riceman
    riceman
    Bad to the bone!
  19. Deuces
    Deuces
    Yeah, it is!!! :D
  20. Deuces
    Deuces
  21. riceman
    riceman
  22. riceman
    riceman
    Here is an update ! 2-25-12 history was made with doug, patty and lori peterson's potvin dragster at sacramento. 7.85 & 7.87 @177 mph. Lori's first time into the 7 second zone ! Oooohhhh yeah !
  23. robber
    robber
    Just as you called it early on in this thread, Riceman! Congratulations to all involved in this unique, old school type build... Great FED story, thanks for the news!:D
  24. swade41
    swade41
    from Buffalo,NY
    Wow, nice to see the old Potvin style blower being put back inro action and running 7's too !
  25. Deuces
    Deuces
    Very cool!!!..:D:):D
  26. Deuces
    Deuces
    Bump!.... I love this build...:D
  27. Deuces
    Deuces
    One more time....
  28. riceman
    riceman
    The latest news is that Doug and Lori put on a wheelie roller . It seems like their blower woes are fixed and Lori is ready to make a fast p***. They have been talking about running the 7.60 cl***. The car has an easy 7.50 in it.
  29. riceman
    riceman
    From the driver, Lori Peterson.
    We did it!! We are now the quickest ever front-mount blower dragster in history! We set the new record today at Sacramento Raceway with a p*** of 7.73 @ 177.9 mph!!! The original record of 7.79 was set in 1965 by Prieto, Cagle & Yates.
  30. swade41
    swade41
    from Buffalo,NY
    Congratulations ! Long time for a record to stand and good luck resetting it even lower.
