who can id this Chevrolet engine?
Discussion in 'The Hokey Ass Message Board' started by belgiumcustomshop, Feb 24, 2013.
  1. belgiumcustomshop
    belgiumcustomshop
    from belgium
    I have this chevy 6cil engine laying in my shop for a long time now, I remember the last owner say its a pick up engine from the 50's
    Some ideas?
    Uploaded with ImageShack.us
  2. Steve Ray
    Steve Ray
  3. USA Tires Sign Joe
    USA Tires Sign Joe
    from Western NJ
    Looks just like the stock six banger I took out of my ol' '55 Chevy Belair.
  4. rtomss
    rtomss
    Yup...that's an early 235 from a truck. It has the truck bell housing.
  5. R Pope
    R Pope
    Two-bolt valve cover is '54 0r older.
  6. p15-1948
    p15-1948
    May not be a full pressure system. Pretty sure 53 car manual shifts still used the dippers and auto's were full pressure. Have in my head all trucks in 53 were still dippers.
  7. Shadetree
    Shadetree
    from Va USA
    see the little triangle plate below the intake! and the short side cover below the spark plugs.
    I believe it is a 235 dipper engine "not full pressure"
  8. junkyardjeff
    junkyardjeff
    It looks like a 1950 to 53 235 with splash oiling like a 216,the 41-9 235s had the same tall side cover as the 216.
  9. Truckedup
    Truckedup
    If it has 18 head bolts it's a 53 only splash oil 235 car engine ?
  10. waldo53
    waldo53
    from ID
    It's fer sure a splash oiler as was pointed out above - the triangular plate just under the exhuast flange is the oil distributor cover, only used on the splasher. Looks to be a '53 by the date code, probably a 235 - but if you can post the numbers that are stamped on that flat pad, just behind the distributor, we can tell you more.
  11. belgiumcustomshop
    belgiumcustomshop
    from belgium
    thanks for the reactions. Here are the engine numbers: CON 4 F93 and 3701946 and the head:
    B10 887
    066
    570
  12. RawDeal
    RawDeal
    from Austria
    yes its a 235 from 1953
  13. belgiumcustomshop
    belgiumcustomshop
    from belgium
  14. Snarl
    Snarl
    splash oil '53 235.
    date code F93 is June 9, 1953.
    Stamped code next to distributor would be more specific.
    If you didn't know the date code:
    It has the 3 bolt side mount (used '52-54), short side cover (not used on 216), and it has the oil distribution cover, which makes it a splash oiler ('53 or older). All that would narrow it down to a '52-53 splash 235.
  15. Dan Timberlake
    Dan Timberlake
    Always thought it was interesting manufacturers felt it was easier /cheaper to manufacture, fit and ***emble the troughs and what not than drill a few holes in the crank.
    In the transition years I can picture they were just " using up " older inventory.
  16. junkyardjeff
    junkyardjeff
    I can never figure out the splash oiling theory,a couple minutes more in the crank drilling jig and a little more time machining the rods and it would have been a full pressure motor.
