I had went to the Truck Shop in Orange,CA and purchased the bushings for the leafs on the rear of my truck. Well they ended up selling me 8 bushings and each set of 4 are different I have had a few issues with them and I think I'm done buying from them. I have called LMC and they supposedly don't offer the shackle bushings.Can somebody look up the bushings in The Truck shops catalog or website and tell me what the correct bushings are? For the rear leaf springs in the front and rear eye's and the shackle? Also how many of each if they are different or all the same. Thanks
go get some plastic with the right durometer and make them on a lathe takes high speed to turn and drill they worked on my semi tractor and surely will work on a truck if you get the right grade, you can buy round pieces of plastic
FYI Shackle/bushings: RAYBESTOS Part # 5761013 NAPA lists this as Front then " Rear" spring? NCP 2741160 Bolt Diameter : .562" Dimension A : 2.12" Dimension B : 2.12" Dimension C : 4" Dimension D : 1.1" Dimension E : 1.1" Bushiing RAYBESTOS Part # 5763325 or 5763325B NAPA lists NCP 2746459 Dimension A I.D. : .568" Dimension B : 2.24" Dimension C : 2.74" Dimension D O.D. : 1.128"
I would measure them because Raybestos is pretty confusing, you can go straight to their catalog a their site. This is what they list for the rear springs. Description Part Number Leaf Spring Bolt Kit Professional Grade; Rear; Two Wheel Drive (4x2); Bolt And Bushing Kit; 4 Per Car 576-5018 Leaf Spring Bushing Professional Grade; Front; Four Wheel Drive (4X4) 576-3317 Leaf Spring Bushing Professional Grade; Front; Two Wheel Drive (4x2) 576-3325 Leaf Spring Bushing Service Grade; Front; Two Wheel Drive (4x2) 576-3325B Leaf Spring Shackle Bushing Professional Grade; Lower; Four Wheel Drive (4X4) 576-3317 Leaf Spring Shackle Bushing Professional Grade; Upper; Four Wheel Drive (4X4) 576-3318 Leaf Spring Shackle Bushing Professional Grade; Lower; Two Wheel Drive (4x2); Except Flexomatic Spring 576-3325 Leaf Spring Shackle Bushing Service Grade; Lower; Two Wheel Drive (4x2); Except Flexomatic Spring 576-3325B I read that as a 2WD takes 6 576-3325s. Here is some application info http://www.amazon.com/Raybestos-576...ing-Bushing/dp/compatibility-chart/B001QV81B2 Ford F-100 Pickup 1962, 1963, 1964 Inner 2WD PROFESSIONAL GRADE - REAR FRONT Ford F-100 Pickup 1962, 1963, 1964, 1965, 1966, 1967 Inner 2WD PROFESSIONAL GRADE - REAR LOWER - REAR UPPER - EXC FLEXOMATIC SPRING - RWD Hoop
I don't know where you are in Socal, but try CW Moss in Orange, or Early Ford Store in San Dimas. Dennis Carpenter makes the shackle stuff for the Ford trucks...makes damn near everything, actually. Truck Shop was strictly Chevy until about 6-7 years ago, so they might not know all things Ford. CW has always been strictly Ford, as such with Early Ford Store. Other option is Delrin round stock and a lathe. I have done that with oddball stuff. Machines easily, so wouldn't take very long. Good luck
I think they are 1.128 or about 1 1/8. I would definitely measure the spring eyes and frame hole to be sure, the springs might be different. Check this catalog out page 95.
