Is a proportioning valve needed???
Discussion in 'The Hokey Ass Message Board' started by Blacktop Graffiti, Feb 27, 2013.
  1. Blacktop Graffiti
    Blacktop Graffiti
    I'm setting up the brakes in my Dad's '41 Plymouth. It has a '79 Nova 10 bolt rear axle(drums), stock '41 Plymouth drums up front and a master cylinder/power booster(disc/drum) from a '79 Ford Fairmont wagon.
    So do I need a proportioning valve or can I just run a tee for the front and back?
  2. HOTRODPRIMER
    HOTRODPRIMER
    I would use one. HRP
  3. supervert
    supervert
    Why are you using a disc master on your drums? I am not sure if that's going to work well, might be way to much master for the drums.
  4. Do yourself a favor and get a Drum/Drum master
  5. Hnstray
    Hnstray
    from Quincy, IL
    ***uming your front wheel cylinders are in good condition, no leaks, I don't think the pressure will be too great on your front drum wheel cylinders. It takes the same line pressure to stop with or without power brakes....but with power brakes the PEDAL pressure required is reduced.
    However, your use of a disc/drum master cylinder suggests you do not have the proper residual valve in the front circuit, IIRC, disc M/C do not use a residual valve. You can add an inline 10# residual pressure valve and solve that problem. They are available from many sources, but I get mine from Speedway.
    You original question was about a proportioning valve. It seems many people immediately say "YES..you need a proportioning valve".....I think the correct answer is "it depends". What it depends on is, whether or not you have a significant mismatch of brake components and/or weight differences front to rear brought on by other mods to the vehicle or a particular combination of parts.
    Given that you are using stock front brakes and a Nova rear end with stock drums, I would speculate that the Nova brakes are about the equal of the original Plymouth rear brakes. Since the car weight isn't changing much...I doubt you will have any problem.
    One way to determine that is to get the car on a dry surface and make several stops with increasing brake pressure up to and including a "panic" stop. What you are looking for is rear brake lockup PRIOR to front brake lockup. Rear brakes locking before the fronts cause directional instability...i.e.. the rear end skids and wants to 'swing out' and subsequently changes your direction of travel. No lockup, no problem, and no proportioning valve needed.
    Ray
  6. Blacktop Graffiti
    Blacktop Graffiti
    Where should I put the inline valve at? I think I might try it without a proportioning valve and if it needs it I can always go back and put it in.
    I'm using the disc/drum because it's what I had. And we are planning on installing disc brakes up front in the near future.
  7. Hnstray
    Hnstray
    from Quincy, IL
    The Residual Pressure Valve (RPV) needs to go somewhere between the outlet port of the master cylinder and the "tee" fitting where the brake line splits to go to each front wheel.
    Ray
  8. Blacktop Graffiti
    Blacktop Graffiti
    So I put it after the tee going up to the master cylinder??? I swear sometimes I think somebody needs to draw me a picture.
  9. fsae0607
    fsae0607
    You only need a residual pressure valve if your MC is mounted lower than your caliper/wheel cyl's.
    They act as a check valve to prevent fluid from gravity draining back into your MC.
    This applies to disc brakes.
    Drum brakes need a 10 lb RPV.
  10. Blacktop Graffiti
    Blacktop Graffiti
    My MC is on the firewall.
  11. Tnomoldw
    Tnomoldw
  12. forty1fordpickup
    forty1fordpickup
    Go to Bill's link above ^^^^^^^^^. It explains everything.
  13. Hnstray
    Hnstray
    from Quincy, IL
    The diagram in the link in post #11 shows two RPV's on the from brake system.......no harm in that.....but in my experience one was all that was needed. 10#'s pressure is 10#'s pressure, whether provided by one valve or two. It also indicates you 'need' a metering valve......I disagree with that. Cars and trucks were built for many, many years without 'metering valves' . The diagram is from a vendor who sells parts. Again, you could put one in, no harm done, but in my opinion, unnecessary. Your call.
    Ray
  14. Fenders
    Fenders
    No, that's not the purpose of a RPV.
    Usually you use a 2# RPV for discs, and a 10# for drums.
    And you need them no matter where the MC is mounted (due to the real reason for using RPVs)
  15. fsae0607
    fsae0607
    Yeah you're right just looked into it. It's been a while since I messed with designing a brake system. Did it way back in college for my senior design formula car. I remember using 2# RPV's for the system specifically because we had the MC mounted down low by the driver's feet, with a mechanical bias bar to take care of the front/rear brake bias. I also remember as part of my research that it does prevent fluid drain back in the situation that the MC is lower than your calipers. That was a fun project! :D
  16. plymouth1952
    plymouth1952
    I used a dodge datona on the 52 mounted in the stock location. I also used a 10 Lb residuel valve on the rear and as I had disks a 2 lb on the front.it stopped better then my driver did. theres shots in my album of the system.
  17. bsa_bob2
    bsa_bob2
    Go get A street rodder magazine. Next find ECI brakes for hot rods etc in the advertiser directory [last few pages in the magazine.]l They will hook you up ,with exactly what you need. There is another company now that does this install in their parts book also. Believe me man. you can get brakes on old kars screwed up quick .and have no idea why this problem is happening ,but everything is new!!!!!!.I have been there and done that, its not A pretty sight , bob s
    ps yes ! they have every combination ofwheel cylinder sizes, and how to match chevy up, with ford.,and plymouth etc. Whatever anyone one is trying!......... to make there kar stop good. HTH
  18. HemiRambler
    HemiRambler
    Are those '41 brakes single servo?
    No way I'd run single servo on the front and duo servo on the rear. YMMV
  19. Blacktop Graffiti
    Blacktop Graffiti
    What is single servo????
  20. BobMcD
    BobMcD
    Non servo has a fixed anchor between the shoes at the bottom of the backing plate.
