Riviera Vibration?????
Discussion in 'The Hokey Ass Message Board' started by greaser41, Feb 20, 2013.
  1. greaser41
    greaser41
    So I finally get some time to mess with my new project this afternoon. After some carb and timing adjustments I was able to get it to start easily and idle good.
    Then I noticed that when I gave it some gas and it would come back down to idle, it would have a bad vibration around the same rpm, but would stop when it got back to idle. Also it seemed like the vibration would sneak in and sneak out radomly while at idle.
    What could it be? Where should I look first?
  2. Boyd Wylie
    Boyd Wylie
    bad spark plug wire.Also have you done a compression check?Could be a leaking valve
  3. JJK
    JJK
    Give it a tune up and double check the motor mounts, also it wouldn't hurt to look at the fan clutch while your in there.
  4. greaser41
    greaser41
    Thanks, I will look into all this.
  5. wbrw32
    wbrw32
    Batter check for flex plate cracks too..
  6. greaser41
    greaser41
    Will do. Thanks.
  7. bowhunt
    bowhunt
    sounds like a usual engine miss my 425 had one went to a pertronix ignition then had idle and run issues ..finally got ahold of dave's small hei and man ..it runs like a ****d ape !!! he takes your stock dist.remans it builds an hei that fits under your stock cap and guarrentees it..it all looks oem..car has never run this good...also timing these things are horrable..if you get lost or need advise on where to get parts i have a few numbers..good luck..ROB
  8. lht
    lht
    check harmonic balancer it might be seperating
  9. greaser41
    greaser41
    Thanks everyone. We are looking at it today. I will let yall know what we find
  10. bobss396
    bobss396
    Take a close look at your fan. One or more of the blades might be cracked at the rivets and is loose. You may have to take it off for a thorough inspection. You can take the belts off temporarily and run it for a short while too.
    Bob
  11. greaser41
    greaser41
    Well, after a closer inspection we determined that the fan is good, and the balancer is good. We did find that the flex plate wasnt lined up correctly with the fly wheel. We fixed that and although not as bad, it still has a vibration. Now we are looking at the torque converter. My mechanic that is helping me with this problem says the only way to prove it is to buy a new one and put it on. Which leads me to my next question. Where can I find a torque converter for this car?
  12. greaser41
    greaser41
    Found a place that will rebuild my converter for $75
  13. ClayMart
    ClayMart
    I have no idea what year or model of carb you have, but some older O.E. carbs had a "dashpot" which kept the throttle blades from closing too quickly when you suddenly lifted off the throttle. Yours may need replacement or adjustment if so equipped.
    Without it, on a quick return to idle, the engine could stall or develop a miss for a few seconds until the idle circuit stabilized and took over. I think there was a tendency for some carbs to be a little slow about stopping fuel flow thru the main nozzles when transitioning from cruise to idle conditions.
  14. greaser41
    greaser41
    I have an aftermarket Edlebrock carb. I can tell you that when driving the car the vibration is just as bad, and never goes away, untill it gets back down to idle
  15. saltflats
    saltflats
    from Missouri
    Can you unbolt the converter and slide it back then start it and see if it goes away ?
  16. wbrw32
    wbrw32
    You have not yet told us the engine you are haveing this problem with....
  17. bowhunt
    bowhunt
    when its running at idle slowly advance your idle and watch your crank pulley ....i had a bad vibration at 55mph that shook the whole car and found my crank pulley is bent got another set from flat top bob in texas ..waiting on a nice day to put it on
  18. Mr48chev
    One more thing to look at that doesn't cost anything. Put a wrench on the bellhousing bolts and make sure that they are all tight and all there. I've worked on more than one car that had a loose bellhousing.
    Before pulling it apart I'd do as Saltflats suggested and pull the three converter bolts out and slide the converter back in the pump and start the engine. If the vibration goes away you have a converter problem. If it is still there you have a problem somewhere on the engine. Eliminate the possibilities as much as possible before pulling it all the way apart or spending a bunch of money.
    I'd look at that flexplate real good too as they do crack quite often.
  19. hoop98
    hoop98
    from Texas
    I changed out many a cracked flex plate, usually for noise on our Buicks.
    If you have clearance you can put two long 3/8 bolts in the bottom bellhousing bolts, drop the driveshaft, take out the crossmember bolts from the frame rails, disconnect shift linkage, undo converter bolts remaining bellhousing bolts, and slide the trans back.
    Then use a long combination wrench (11/16 I think) to unbolt the flex plate.
    Be sure to mark the bottom of the flexplate so you can line up the new one, it only goes on one way.
  20. I would never suspect a turbo 400 of failing, but I guess anything is possible.
  21. harpo1313
    harpo1313
    from wareham,ma
    Also check your exhaust system,contact with the frame or firewall will vibrate at certain rpms.
  22. greaser41
    greaser41
    Sorry, its a 425.
    The car doesnt have the th400, it has the dynaflow trans.
    Thanks guys for all the help. I need all I can get.
  23. mrconcdid
    mrconcdid
    from Florida
    I had an old carter carb that the metering rods fell out and into the bowl, it would crank and run, but shook and rattled at idle (very bad), like you, I check rotating things, like harmonic bal, clutch and so on, even replace a few things before I found out it was the carb.It shook at 850-1000 rpms then leveled out just fine, and even pulled good under a load. I reinstalled the metering rods, and the problem was gone.
    Good luck.
    Godspeed
    MrC.
  24. Sweepspear
    Sweepspear
    I ***ume this below is what you lined up?
    On a nailhead, the flexplate will have a hole through which you line up a dimple in the hub of the crank. There is no particular pattern for the bolts to line up to bolt on the flexplate, i.e. they're symmetrical, so all the holes line up in any rotation. If you bolt it up out of balance, it'll shake your fillings loose.
    When I rebuilt the 425 in the '66 Riviera I owned, I learned this the hard way. I just thought I got lucky the holes lined up on the first try.
  25. greaser41
    greaser41
    Wow, never would have thought about checking that. Thanks, I will check it out.
  26. hoop98
    hoop98
    from Texas
    If it's a balance problem it should come in multiples of RPM.
    Example 800-1600-2400 although the amplitude will change.
    Words from EngineBuilder.com
    The important thing an engine builder looking at this powerplant should do is find the correct year before starting the rebuild. “Certain engines cannot be used in some Buick cars because of bellhousing, engine mount, block, oil pan and crankshaft changes,” Martin explains. “Plus, since all Nailhead engines were externally balanced, mixing dampers and flywheels with some models is not going to work.”
    Getting your balance with a the Buick is critical. “Because all Nailheads are externally balanced, the flywheel/flexplate must be installed with the index holes lined up,” Martin explains. “They can bolt on six different ways but only one way will be vibration-free! The 1957-’66 Engines MUST have their dampers tightened to 225 lbs ft. or the crank and damper will be damaged. They are a light press fit so the bolt must be this tight.”
    Nailing Down The Buick Nailhead
  27. greaser41
    greaser41
    Thats what it does when its in park. The vibration comes in and out at a certain rpm. When I am driving it, it seems like the vibration never goes away.
    We are pulling the converter off today, and I am taking it in to get rebuilt tomorrow. Hopefully when the rebuilders take it apart they will be able to find something wrong with it.
  28. greaser41
    greaser41
    Well, I got the trans pulled yesterday, and found out the trans mount was completly shot. After checking all the local parts shops, we discovered that the mount is obsolete. After a very stressfull internet search, I found a company in Arizona that rebuilds them. He isnt cheap, but what other option do I have?
    The name of the company is GM Obsolete. I ordered the mount from them, so it will be headed my way as soon as he recieves my core in the mail.
    Here is his website. http://www.gmobsolete.com/
  29. greaser41
    greaser41
    Oh yea, I also dropped the converter off to be rebuilt. When they dis***embled it, they found that the shaft bushing was worn pretty badly, and also one of the small springs was missing. They found some traces of metal shavings, and figured that was what was left of the missing spring.
  30. bobss396
    bobss396
    A bad transmission mount will easily give you a random vibration, be nice if you could have isolated that first, oh well... the main thing is between the mount and converter, it should do the trick.
    Bob
