Gotta have some h.a.m.b. Help
Discussion in 'The Hokey Ass Message Board' started by drw47, Feb 28, 2013.
  1. drw47
    drw47
    Have a Lincoln, Merc, ford 8 inch rear end under my '29 Willys. When I bought it, was told it was a '70,s Maverick, Year unknown. Ok, want to replace the shoes and drums. Drum outside dia-11.5/8"....Drum overall heighth-3.25".... shoe contact surface dia inside-10"....shoe contact surface inside 2.00" wide... Actual shoe width 1.75"....5 lug, 4.5 bolt pattern. Everything is great so far to match a 73' mor so Maverick, but when I get the new drums, the big hole in the middle that fits the locater on the axle, is TOO SMALL. It is like 2.43" and mine is 2.78" . I found some drums with 2.78 center hole, but they are for '75 Cougar and have wider shoe contact surface that will not fit . What have I got ? If you have a 5 lug, 4.5 lug pattern, FOMOCO 8" rear end and know what it came off of, please look at the Hub hole and if it is 2 3/4+, small shoe (1.75), 10" drum, please let me know what make and year it is ! Thanks
  2. stillrunners
    stillrunners
    from dallas
    can you give us a backing plate to plate measure - it might help with the id...
  3. kscarguy
    kscarguy
  4. drw47
    drw47
    The back plate to backplate is 49 1/2", stillrunners
  5. spooler41
    spooler41
    Try looking at '68 Mustang rear ends, I used a '68 8"in a '49 Willys panel , it was narrow enough that I could use 10" wheels and had no clearance problems.
    ................Jack
  6. 325w
    325w
    Can't you just make the axle hole bigger?as log as everything else is correct.
  7. drw47
    drw47
    Dont have a lathe handy. These drums came off something, just need to know what...
  8. need louvers ?
    need louvers ?
  9. sawbuck
    sawbuck
    from 06492 ct
    1984 85 f 150 ... small brake shoe....light duty ....they are shaped a little different but they work ...
  10. kscarguy
    kscarguy
    74 - 77 Maverick had the bigger center hole in the drums.
  11. 1great40
    1great40
    from Walpole MA
    The larger hole started when they went to disc brakes. A typical Ford wheel would hit the caliper and the disc hub needed to be stout so when Ford made the disc brake change, the new wheels had a larger hole so the rear axle hubs were bigger too. So like others have said it's probably from a mid 70's rear when the original car it came from would have had disc brakes in front.
