what did you get done today
Discussion in 'The Hokey Ass Message Board' started by 4rod, Mar 2, 2013.
  1. 4rod
    4rod
    I was able to pull this old grill out of the shed and prep it to sell...after blasting it and some grinding it turned out to be in pretty good shape
  2. tfeverfred
    tfeverfred
    I polished my valve covers and drove around to show off.:D Then, I sat down and worked out a plan to replace my front shock set up. I'm going with a California Custom Roadster set up. I also started a wish list for a possible cosmetic front axle. I think a forged, drilled and chromed dropped "I" beam is in my future.
  3. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    More than I can list... but tops of the list would be priming and blocking my firewall and kick panels, got 2 rounds of that done. tomorrow onto the fine stuff, and maybe paint this week!
  4. 76ironhead
    76ironhead
    Not a dam thing birthday party in the middle of the day.
  5. clean cut creations
    clean cut creations
    Sold a bunch of **** I had lying around on "that" auction site...
  6. motoandy
    motoandy
    from MB, SC
    replaced a toiled in the bathroom.
  7. metalix_421
    metalix_421
    I got about 90% of my foundry built :D
    really should be working on the olds but ya know
  8. Tearing down an old house (national folk pre-railroad and post-railroad) 'til I tore a calf muscle, lifting an old upright piano up into another room.
  9. The37Kid
    The37Kid
    Put a four bolt Factory exhaust manifold on my 354 HEMI just to see how cool it looked. Deck hid handle arrived for the Roadster and it is Perfect, one I've looked for for a good 4 years now. Need to sell more on "that auction site" Bob
  10. raidmagic
    raidmagic
    N.O.T.H.I.N.G. Caught a case of the lazys
  11. fxcomet
    fxcomet
    Got my headers installed on my Willys, worked on the interior headliner, cleaned up the garage a bit.
  12. Rusty O'Toole
    Rusty O'Toole
    Below freezing again today so went out and cleaned the garage some more. Got a cheap deal on some heating oil last week ($1 a liter) so put the heat on and warmed it up to 45F.
    Went to Canadian Tire to get some new pressure gauges for my air compressor, they wanted too much for them but I did get some new tools on sale, 1/2 drive and 3/8 drive air wrenches and shiny new combination wrench sets, metric and inch sizes.
  13. tommyd
    tommyd
    from South Indy
    Fixed a out of round crank pulley problem and banged around on my sons drag car. Oh yea, also bought a set of Pontiac M/T valve covers for my wall off THAT site.
  14. winduptoy
    winduptoy
    Pizzed off the wife
    Adjusted the valves on the banger
  15. mikeallcars
    mikeallcars
    Chillin to cold outside no place to wok on cars at present till I get my garage finished .
  16. Got another rick of wood for the shop stove stacked ti added a few logs to the fire Sat down snapped a beer & started dreaming about What I Need to get done .Its after 5 here Maybe tommarow I wont have any excuses Larry;)
  17. 1948plymouth
    1948plymouth
    from Minnesota
    I had 3 beers --- one for each bruised rib from the last time I worked on my truck.
  18. Hung the quarters and catwalk for the last time on the t bird I'm working on. Another hour or so on it and I'll be welding the entire back half back together. Been a long haul...........
  19. Swiss50chevy
    Swiss50chevy
    drilled front fender on 56 for belair trim. worked tailpan on 56, getting it preped for primer.
  20. Mike is it snowin' up your way? Down here it snowed all night and all day. Miserable outside.
  21. pearl31
    pearl31
    Advanced the timing to get 19 in of vac the highest I could get, put new springs on the rear coilovers with a higher spring rate. I was at the limits of adjustment and the coupe still bottomed out on a particular spot on the freeway. If there is a spot here there is a spot somewhere else on the road. I don't need a broken shock mount. Put the coupe in a car show at the local advanced auto parts.
  22. jazz1
    jazz1
    Went out to seal up leaking manifold on my binder with some Rightstuff,,,but got sidetracked and sandblasted,primered and painted my 53 Buick,,ya so it's a Hubley,,I did something today..
  23. DirtyDave
    DirtyDave
    Primed and painted my grill, bought propane and kero for the garage, changed the harm bal seal on my timing chain cover, coordinated sale of my prior choice of gas tank, welded my front brake hose tabs, coated the wheel wells and watched the Nationwide race. Typical Saturday.
  24. Devin
    Devin
    from Napa, CA
    Wires my tail lights and turn signals.
  25. Vin-tin
    Vin-tin
    Spent 4 hours today freezing my @ss off at the local u-pull-it. Needed to get some parts for my daughter's O/T car which met a fence a few weeks ago :rolleyes:
  26. txturbo
    txturbo
    painted my new driveshaft for my 55 Chevy 3100 and unloaded my next project truck...40 Ford.
  27. Bagged50Buick
    Bagged50Buick
    Went ice fishing and caught 2 pickerel and a good buzz.
  28. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Early spring cleaning. Rolled the truck outside to clean the garage. Managed to snap a picture of it. [​IMG]
  29. Benchdawg
    Benchdawg
    Drove the 33 for a couple of hours.
    Detailed the rear spring, costed it with Gibbs oil. Installed knobs on the lower door slide locks.
    Cleaned the **** off the windows from the trim guys. They did a pretty good job, but weren't too careful with the glue.
  30. Benchdawg
    Benchdawg
    Oh ya forgot the most important part ImageUploadedByTJJ1362278497.247114.jpg
