welding question
Discussion in 'The Hokey Ass Message Board' started by kscarguy, Mar 4, 2013.
  1. kscarguy
    kscarguy
    I need to weld a 1/4" thick bracket to the end of a 1-1/4" .120 wall DOM tube. The bracket will have a hole and slide over the tubing.
    I need the bracket to be at a true 90 degree to the tube. The angle is important.
    If I add a 90 degee gusset and tack the gusset and bracket first, will the bracket remain at 90, or will the shrinking of the welds change the angle?
  2. homemadehotrod
    homemadehotrod
    it should hold it but let it cool completely before removing the gusset.
  3. kscarguy
    kscarguy
    I meant that I would leave the gusset welded in.
  4. homemadehotrod
    homemadehotrod
  5. kscarguy
    kscarguy
    You have not seen my welding skills...ha!
  6. EXracer64
    EXracer64
    from nj
    Tack and check angle each time if your that worried about it. Smaller the tack, the less pull.
  7. homemadehotrod
    homemadehotrod
  8. d2_willys
    d2_willys
    from Kansas
    What about the angle 90 degrees from the gusset placement? You would need another gusset to keep the tube perpendicular all the way around.
  9. kscarguy
    kscarguy
    ***uming the bracket sticks out towards 9 o'clock position, I thought I would start the tack the bracket at 12 and 6 positions, so it can rotate and adjust slightly to 90 degrees, then tack the gusset at 9. Do I tack the gusset at the innermost point first or at the ends first?
    The angle perpendicular is not as critical.
  10. EXracer64
    EXracer64
    from nj
    judging by the diagram, there isnt enough bracket.
  11. kscarguy
    kscarguy
    you are right, not enough bracket for a second gusset.
  12. EXracer64
    EXracer64
    from nj
    ship it here, lol
  13. kscarguy
    kscarguy
    I know, live dangerously and chuck it in a lathe and try to face cut it...
  14. SUADES40
    SUADES40
    from TRACY CA
    If you are worried about the tube moving towards the gusset and breaking the 90 degree mark, I would fit the gusset snug up to the pipe and tack weld the gusset really good to the 1/4 inch plate. That way when you tack the pipe to the gusset, It shouldnt have any room to pull. i always over clamp eveything I weld so it doesnt move out of measurment. If you can, clamp the hell out of that pipe
  15. any advantage to welding the gusset to the pipe first , then if you need to you can chuck it in a cut off saw to square it up, then weld the plate to the front? just a thought , sounds like you weld like I do :)
  16. rpu28
    rpu28
    from Austin
    If the part is not very large, you could weld without a gusset, chuck the pipe in a lathe, and cut the plate so that it is at a perfect 90-degree angle in all planes.
    For that matter, you could chuck the pipe in a lathe so that the amount sticking out from the chuck is the same as the thickness of the plate, and push the plate against the chuck to keep it square. After welding, you'd probably still need to face the plate to nail the right angle.
  17. trollst
    trollst
    Patience here...tack one side, check square, tack the other side, check square, tack a third point, then the fourth, all evenly spaced. Weld your **** off, just take your time tacking, no gusset required, unless the gusset has to be there. Once its tacked square, its not likely to move.
  18. BillyM
    BillyM
    It's pretty much a given that it's going to pull, and even if you weld the gusset on, the plate is going to get a slight warp in it. If it's really that important to be exactly square and straight, you're going have to either machine it, or hand dress it. That was one of the first things I learned in trade school was how to hand fit something critical. Get out your machinists square and a file....or a piece of gl*** and your blue ink and go at it!
