Can you ID these brakes???
Discussion in 'The Hokey Ass Message Board' started by abakerman, Mar 4, 2013.
  1. abakerman
    abakerman
    Ok, I want (as step one in getting this bucket back on the road is)to upgrade to front disc brakes. But I have no idea what brakes / spindles are on there now. I am pretty sure they are Ford since they are a 5 x 5.5 pattern. And most all the other parts off this thing are from a 1972 F-100. On the back plate it is stamped 48477 and BendIX. Do I even need to know since really all I need is a plate that will bolt to the spindles?? any thoughts/ ideas?
  2. Blakmerk
    Blakmerk
    from St.Joe MO
    They look like F-1 to me.
  3. Raven53
    Raven53
    from Irwin Pa
    I cant get the pics to enlarge but I think the backing plate is 39 to 48 ford. I see the accentric adj nuts on both sides I can check my parts manual for you tomorrow.
  4. abakerman
    abakerman
    Thanks, also anybody know of a good, resonably priced, conversion kit?
  5. alchemy
    alchemy
    Not 39-48 Ford, not F-1, not F-100 up to '56. Must be something later than that. Are you sure it's not a 5x5 inch?
  6. abakerman
    abakerman
    Yep, they are 5x 5 1/2 for sure. The f100 was a 1972...might be that?
  7. abakerman
    abakerman
    Hubs don't appear to be redrilled. Front axle is some rough looking I beam drop axle. Man I apperciate all the guesses and ideas!! Taking over some other guys project, that was probably six other guys projects isn't easy, but I'll get this thing straightened out eventually
  8. abakerman
    abakerman
    ha, well springs and shocks are "homemade"...
  9. RMR&C
    RMR&C
    from NW Montana
    My guess is 42-47 Ford pickup. That is what the drums/hubs look like to me.
  10. flopalotofit
    flopalotofit
    Cant be from the seventys, no slack adjusters at the bottom...Im going with early ford truck..google those numbers
  11. abakerman
    abakerman
  12. alchemy
    alchemy
    Wartime Jeep/Willys had a 5.5 inch bolt pattern. Maybe later too?
  13. abakerman
    abakerman
    So now the million dollar question...which converstion kit do I get? Do I just pick one and know I might have to redrill the mounting plate. Does anyone know of one with a 5x5.5 pattern. Looks like most are 5x4.5??
  14. alchemy
    alchemy
    Sure, just get a kit for a '32 Henway, and maybe redrill the holes a little.
    Really, you need to know what spindles you have before you can order anything. And I'd bet you will be money ahead if you buy old Ford style stuff and lose this unknown front end.
