Aluminum intake help
Discussion in 'The Hokey Ass Message Board' started by IRISH13, Mar 4, 2013.
  1. doozcoupe
    doozcoupe
    My Winters manifolds have the W in the middle of the snowflake. They are off 68 & 69 Z-28s.
  2. Good job!
    Way to get after it! :)
  3. 32Tudor396
    32Tudor396
    Weld a nut...let cool the heat will do the work for you.Should shrink that plug a little.
  4. raengines
    raengines
    from pa.
    I'd drill it and retap
  5. pdq67
    pdq67
    The single plane Duntov intake that has the runner that run's from each bank in the back is a good one if it is tuned properly.
    It supposedly keep's those two runner's from robbing each other. Thus balancing the air supply port to port.
    pdq67
  6. in2hotrodz
    in2hotrodz
    from Spiro, OK
    Come on fella's, he got it out 4 days ago......
  7. 32ratsass
    32ratsass
    I realize it's too late to help because it's already out, but why didn't anybody suggest drilling the center out, and using an easy-out, with heat?:confused:
  8. T Achilli
    T Achilli
    from walworth
    I have 2 Holley Strip dominator single planes with the winters logo. They must have cast them for holley for a period of time.
  9. 66tintop
    66tintop
    from Canada
    when it comes to stubborn **** like stripped threads, broken bolts and other messed up stuff , just take your time and will work , leave the BFH in the tool box , be like a Honey Badger and fear nothing , persistence pays when **** is screwed up, :D:D:D
