What lubricant should I run in a 9" Ford differential?
Discussion in 'The Hokey Ass Message Board' started by billsat, Mar 7, 2013.
  1. billsat
    billsat
    The rear end came out of a Taurus and is not positraction. There are too many lubricants to choose from, figured I'd ask the HAMB world. Thanks for any help.
  2. 32ratsass
    32ratsass
    80-90w differential lube. I use, and like Royal Purple.
  3. billsat
    billsat
    Thanks for the info.
  4. 39 Ford
    39 Ford
    90 weight is fine, Vavoline a**** others has it in quarts with a pouring tip so its easy to get it in.
  5. A Taurus???
    I thought they were front wheel drive. :confused:
  6. chaddilac
    chaddilac
    It was a type... Thesaurus!! :D
  7. pressuredrop
    pressuredrop
    from mesa AZ
    Good point... They are front wheel drive
  8. Maybe he's building a Cord Hot Rod. :D
  9. 29AVEE8
    29AVEE8
    The OP said "..it came out of a Taurus..." Maybe it was in the trunk.
  10. joel
    joel
    I use 75w90 Amsoil
  11. Ebbsspeed
    Ebbsspeed
    Front wheel drive was my first thought too, and definitely not a 9" ring gear.
  12. tfeverfred
    tfeverfred
    Trick question,
  13. 38Chevy454
    38Chevy454
    Real Ford 9-inch use good old 90 weight gear oil, use the additive stuff for limited slip if you need it.
