Features Vintage Multiple Carb Intake Pictures
Discussion in 'Traditional Hot Rods' started by PKap, Feb 9, 2013.
  1. PKap
    PKap
    from Alberta
    Thanks. In my mind, these intakes look like what the earliest guys built for their roadsters. They just look so simple, but I know of a few that ran terrible.
    I will build one for my big cad, and I am willing to deal with the h***le and possible negative performance, but I hope to learn from past lessons if possible, and at least start with a design that has a chance of success.
  2. smurftastic
    smurftastic
    Mine. [​IMG]
    roddering and 6inarow like this.
  3. Rocky
    Rocky
    Classified Editor
    Some old Pontiac setups I've had or still have..
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Where'd that finned noname valve cover come from?
  5. smurftastic
    smurftastic
    Tom Lowe, it's a new design.
  6. PKap
    PKap
    from Alberta
    Any one have good pictures of linkages with two rows of carbs? What is the best way to make them work in unison?
    Thanks!
  7. PKap
    PKap
    from Alberta
    Thought I would bump this for the weekend. Anyone with more pictures?
  8. sedan33
    sedan33
    I'll play. Here's my Edmond Speed that is going on the fresh stude engine in my 33 that I'm currently building.
    ls1yj likes this.
  9. James427
    James427
    I just picked up this one today and have no idea what it is!! lol
  10. PKap
    PKap
    from Alberta
    That looks great! What's the engine out of? And what carbs are you running?
  11. Paul
    Paul
    Editor
  12. Powerband
    Powerband
    not real exotic but Offy', Holley and ****** work for me:
    [​IMG] . [​IMG].
    <!--[if gte mso 9]><xml> <w:WordDo***ent> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:ApplyBreakingRules/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:UseFELayout/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDo***ent> </xml><![endif]-->, Offenhauser Tri-Power 3X1 aluminum intake manifold w/ Offy progressive linkage, Modified Holley 1904 series gl*** bowl carbs , ****** long tube dual out headers... <!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} </style> <![endif]-->
  13. PKap
    PKap
    from Alberta
    Hey Paul what are you running this in?
  14. Paul
    Paul
    Editor
    I had it in a '36 Plymouth Coupe about ten years ago, not too many pictures of it with that setup but it ran very strong
    built for street strip 454 with Chevy rectangle heads
    typical late 60's style big block stuff put together right
    here's a ****py old clip of it when I first put it on
  15. Alfster
    Alfster
    Real hot rods have lots of carbs..... [​IMG]
    A small block Chev with a 4 barrel may perform well but it doesn't look like a hot rod motor.
    I built this set up for a Y block Ford many years ago.
    And this one for a GMC six...............
    jimmy six and 6inarow like this.
  16. Normbc9
    Normbc9
    Here are a couple from over four decades ago.
    Normbc9
  17. 29tudor
    29tudor
    Just found this, kinda cool. Good luck finding one though
  18. hemi rodder
    hemi rodder
    from NB Canada
    i am running this dragstar on my hemi, actualy i have it very streetable
  19. lostn51
    lostn51
    from Tennessee
    I have always run multi carb set ups on all of my cars and unfortunately I do not have any photos to post because I am in the process of moving. But since I run mainly small block Fords there is not a lot of variations to post but the one that I would love to get would be the inline Autolite if I could find one. I have seen a couple at the big Ford swap meet in Columbus Ohio through the years but they were not cheap!
    Billy
  20. HarryT
    HarryT
    Homemade manifold with Bendix Stromberg WW carbs.
  21. hemi rodder
    hemi rodder
    from NB Canada
    also had the horne-cragar 4x2 for my hemi, but sold it in favor for my 8x2
    ls1yj likes this.
  22. PKap
    PKap
    from Alberta
    That is awesome! This is what I want to build on my 472. It looks like the carbs are feeding the cylinder on the opposite side of the engine from their mounting position. Do they also have some sort of balance chamber tying them together? Is idle running off of all carbs or just two? Are the throttles running together or progressive? Thanks for posting.
  23. Pretty sure that's for a Y-Block Ford or Mercury
  24. nali
    nali
  25. v8paul
    v8paul
    from england
    This is mine... 6 Holley 94's on a 354 Hemi, runs fine on the street. I'm using a progressive linkage, mainly runs on the two middle carbs.
    I have some shots without the carb bodies, also have some video of the linkages moving. A bit boring but might be of interest on my website:
    http://www.heminutter.com/holley-94-linkages/
    Its a bit messy but it also connects to the tv cable for the 700r4. Takes a lot of effort to push the pedal down :D
  26. This is my 54. 235 with fenton dual carb intake and fenton header. wayne valve cover and side cover.
    Later,
  27. 1952henry
    1952henry
    nice!
  28. oldspert
    oldspert
    from Texas
    I have four deuce Horne for early Olds. Pics are here on the HAMB somewhere.
  29. Alfster
    Alfster
    Neat throttle linkage. When I built my six carb set it took ages to set up the linkages.
  30. bjinx
    bjinx
    Thought I would bring this back up, love multi carbs.
