48 carb fuel inlet threads 70% gone
Discussion in 'The Hokey Ass Message Board' started by guy1unico, Mar 3, 2013.
  1. guy1unico
    guy1unico
    Can you tap these out or repair?
    I want to hang onto this center section if possible.
    Thank you,
    Guy
  2. elmitcheristo
    elmitcheristo
    I have seen alot of attempts at repairing them. Some were functional, but not very attractive. I'll be watching this thread.
    -Mitch
  3. You could use the old formula JB Weld on the threads.
    It will not leak/But it will never be able to be removed either.....
  4. hari kari
    hari kari
    from michigan
    Uncle max sells a br*** insert that will fix them. That is the best fix. Or you can buy an oversized needle and seat @ vintagespeed.
