53 merc front sheetmetal on a 53 ford?
Discussion in 'The Hokey Ass Message Board' started by custom53, Jan 6, 2011.
  1. custom53
    custom53
    does anyone know if a 53 merc frontend will bolt to a 53 ford.
  2. Squablow
    Squablow
    I've seen it done, I know it'll fit the firewall, but not sure about wheelbase.
  3. Sancho
    Sancho
    The Mercury front end is longer than the Ford. I set a Mercury hood with the raised "scoop" on my Ford to see if it would swap, it was quite a bit longer.
  4. custom53
    custom53
    thanks. i really needed to know about the hood. i dont know if it will fit in the rear. i know the hood is not as wide as the ford.
  5. bulletproof1
    bulletproof1
    from tulsa okla
    i always liked the merc hood scoop..
  6. 53sled
    53sled
    from KCMO
    b*** can make it fit.
  7. desertdroog
    desertdroog
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    This is what you have in mind? This is a member on another site,pm me for contact info.
  9. custom53
    custom53
    thanks guys. i guess it will fit.
  10. custom53
    custom53
    i made the mec hood fit the ford fenders. i cut the edges off both hoods. i welded the merc hood to the ford edges (i left 1 inch on the sides). i then trimmed the rear to fit the ford. it looks pretty good. i will post pics soon.
  11. custom53
    custom53
    here are some pictures.
  12. custom53
    custom53
    the merc hood was too long. i has to remove about 3 inches from the back. it was also to narrow. i cut my original hood up to make this fit with my ford fenders. i left about an inch and a half on the sides of the ford hood. i cut the merc hood right on the edge. now i have to make the front sides and finish welding it up. i think i will make the scoop functional.
  13. 54rat210
    54rat210
    Looks sick so far :D
  14. custom53
    custom53
    thanks. when i finish this, i will finish making it a hardtop. i started last year i hope to get it done this year.
  15. WWinIL
    WWinIL
    3" wheelbase is exactly the difference between the '52 to '54 Merc's and the Ford's. And it's all from the cowl forward. Looks good!
