Best 36 Ford Aluminum radiator
Discussion in 'The Hokey Ass Message Board' started by 26 FlatRod, Mar 6, 2013.
  1. 26 FlatRod
    26 FlatRod
    I am replacing the old aftermarket copper radiator in my 36 Ford and want to get the best quality, best cooling aluminum radiator I can get. The engine is a 410 hp 383 chevy so it is not too wild, but the old radiator had poorly made brackets on it and it did not cool very well when moving slow.
    I would like a radiator from a company who makes aluminum radiators specifically for 36 fords so I know they will fit well. I am talking to Performance Rod and Custom right now, but this would be a custom radiator for them and I would have to supply all the dimensions to make sure it fit. I know about Griffin, Be-Cool, Walker and Afco but I do not know which one would be best or if they make a standard mounting 36 Ford Radiator. I will check intothem next.
    Any advice on a good 36 Ford aluminum radiator would be appreciated.
  2. uncle buck
    uncle buck
    I also would like to know too. My aftermarket radiator fits so poorly I gave up on trying to line up the hood.
  3. Weasel
    Weasel
    Aluminum radiators ****. They are less thermally efficient at heat transfer than br*** and copper and many of them are cheaply built with epoxied instead of brazed cooling tube - aren't they Griffin? I have thrown three away that have failed....
  4. trollst
    trollst
    Me too, the one in my 36 pickup is the stocker recored, after two aluminum failures, I went back to br*** and copper, way better now.
  5. 1951Streamliner
    1951Streamliner
    from Reno, NV
    Copper is better than aluminum.
    The only reason people think aluminum is better is because race cars use them because they're lighter.
    I have an aluminum radiator in my 46 and would like to change to copper someday.
    Aluminum is more likely to crack
  6. Halfdozen
    Halfdozen
    http://www.bricethomasradiator.com/store/category/ford-radiators/page/3/
    I bought a '40 Chev rad from these folks, was quite impressed. Multi- generation family biz, American made product, great to deal with. The top tank is a one piece stamping with radiused corners, which I personally like better than a welded tank. At my request they left mounting brackets and filler neck loose in the box, so I could position and weld them as required for my car. Price was right too.
  7. tommy
    tommy
    Personally I think it's more of a status symbol than any performance up grade. An original Henry 36 copper radiator will cool most every V8 engine to run at 180*. That is all I care about I don't want to pay for possible potential cooling that I will never need. Aluminum radiators look like **** on traditional cars.
  8. txturbo
    txturbo
    copper/br*** radiators are more efficient...but heavy. Aluminum is lighter and stronger and you can have fewer wider tubes with aluminum. There are cheap ones that are stamped and epoxied and there are good ones. The one I have in my 55 Chevy right now is all welded with billet necks and the tanks aren't just stamped rectangles like the cheap ones I've seen. The tanks actually look just like the originals. If I painted it black you couldn't tell the difference. All this and it was $249. This radiator is a work of art.
  9. mow too much
    mow too much
    ''Aluminum radiators look like **** on traditional cars''
    I agree, there is nothing uglier than seeing an aluminum radiator washing out the grille on a nice car, I see so many nice 55-57 chevy's with them and it just kills the car........If you have one PLEASE paint it black.;)
  10. 36couper
    36couper
    from ontario
    I had an aluminum rad in my 36 coupe. I switched to a walker rad after the aluminum rad sprung a leak. If you end up with an aluminum rad be sure to get one that is repairable if it leaks. Mine wasn't and I ended up selling it for $50
    The walker rad cools way better and maintains a 180* temp consistently compared to the aluminum
  11. tommy
    tommy
    I p***ed on a 400 dollar aluminum radiator for my 56 and kept looking. FE Ford in a 56. Eventually I found an original for a 100 bucks. I was tempted but the guy would not come down and I really wanted a stocker. being on a fixed income (retired) price is the first consideration for me. some times you have to pay the price for parts that are no longer made. I rationalize that by adding up all the savings from my adroit shopping.:D
  12. Don's Hot Rods
    Don's Hot Rods
    from florida
    I'll voice an opinion on the other side of the argument. I have had a ton of br*** radiators and in recent years have gone to aluminum. I won't go back. I find the aluminum ones more efficient by far as long as you buy a quality brand. I am using PRC exclusively now and they will custom make one to your specs, and it will cool any motor you throw at it. I had a hard time getting the 350 sbc in my 23 to go over 170 degrees on the hottest day here in Florida, and that was with a 192 thermostat.
    But the OP didn't ask for if he should do it or not, just who makes the best one, so my suggestion is to call PRC and have a talk with them. I know some people hate em, so just put br*** in your car and don't worry about what others put in theirs.
    Don
  13. FalconMan
    FalconMan
    from Minnesota
    I have gone through 2 PRC radiators in my 36 3W....never again will use an aluminum radiator.
  14. ironandsteele
    ironandsteele
    I'd think twice about aluminum......
  15. 62nova
    62nova
    Sorry but I put a Griffan into my truck and it dropped the temp about 15 degrees and it's still fine after 8 years or so.
  16. junk yard kid
    junk yard kid
    I got a griffan aluminum one in my 56 chevy for 15 years. It still cools it but has all these little leaks that make all this anti freeze crust on it. It looks like **** and i hate it. If i didnt have so much other stuff i needed id get a copper br*** one for it. One day though. Only new ones ill buy are copper/br***. S**** is worth more anyways.
  17. GassersGarage
    GassersGarage
    U.S. Radiator has a 4 row. I use one of their 4 row triple p*** radiators in my '52 Chevy with A/C and it works great. I use a mechanical fan and shroud too.
    olscrounger likes this.
  18. Dreddybear
    Dreddybear
    A good aluminum radiator will beat a ****ty br*** one. A good br*** one will beat a good aluminum one. A GREAT br*** one is unbeatable. (Except on the track) :)
    All that being said I have a little mustang 3 row br*** unit in my model A cooling a '59 Caddy 390.
  19. 26 FlatRod
    26 FlatRod
    Thanks for all the feedback. Thats great that you guys all had such rotten luck with aluminum, but that does not help me steer clear of the bad ones. For all I know you are all talking about the same mfg that went out of business 5 years ago.
    I would appreciate some detail, like who made the radiator, how long did you run it and what went wrong. Did it just start leaking one day? did you get a cheap aluminum one that didn't work, then switch to a really nice br*** one? fill me in a little.
    To get the ball rolling I will tell you my story. I finished the 36 10 years ago. I had heard that Custom Auto Radiator made a nice combination Radiator/Condensor for a good price so that is what I used. I probably should have known not to use the thing in the first place because the mounting brackets were much thinner than the original Ford radiator. But I wanted to get the car done and it fit well so I just moved forward. About a year after finishing the car I had to take the radiator out to get a small leak fixed. Nothing happened, it just started leaking from using the car.
    last year I noticed that the bracket on my top tank was about 1/2 unsoldered from the tank. this bracket holds my hood on and it would not be fun if it flew off. After that I decided to get a new radiator that was made better. Since I was looking I figured I would look for one that cooled better than my current one as well.
    I have heard that because of the structural differences, aluminum radiators can actually cool better than br*** or copper even if the material itself has lower efficiency. If I can find a good quality aluminum radiator that few people complain about, then I will get one. Otherwise I may look for a better quality br*** radiator.
    PS: I agree I do not like the looks of an aluminum radiator, but I was planning to paint the tanks and just fog the front and back of the core just so it is not bright aluminum
  20. vert1940
    vert1940
    had trouble with two walkers...top and bottom tanks leaked,and mounting points were not welded securely.....changed to afco aluminum and have been running for 12 years with no problems.
    recently bought a brice-thomas aluminum for a model a coupe,but have yet to try it.the people there are great to deal with.....they have been making radiators for semi's for years and in the last several years branched out to the antique cars
  21. 26 FlatRod
    26 FlatRod
    This is what I have heard about aluminum as well. Where did you get your radiator. That is the kind of place I am looking for.
  22. 26 FlatRod
    26 FlatRod
    Where did you buy the aluminum radiator that leaked? where did it start leaking, how many miles did you have on it. How long have you had the walker?
  23. 26 FlatRod
    26 FlatRod
    Thanks for the positive feedback about aluminum. can you tell me what br*** copper radiators you were using before and why they failed? Have you ever had cooling problems with a br*** rad, replaced it with an aluminum one, didn't change anything else and the problem went away? I would think that is the only way you would know for sure that the aluminum radiator is better.
    How many PRC's have you used, what did you put them in and how long have you run them? I am talking to PRC now. So far they sent me a very amatuer sketch of a 36 Ford Radiator and said it would bolt right in. However this sketch did not match my current radiator with all the stock mounting brackets. I asked if they would build one to match all my current mounting points and they agreed, but told me I would have to supply the drawing.
    You are correct that I did not ask if I should use aluminum, but I would say If everyone that responds says do not use aluminum and actually has a good reason behind it, I might have to change my position.
  24. 26 FlatRod
    26 FlatRod
    Was the griffin new when you got it? why did you install the griffin in the first place, were you replacing a copper one? Has it leaked since the beginning? if not, how many miles did you have on the car when it started leaking?
    Sorry for all the questions but it helps to know the whole story.
  25. Weasel
    Weasel
    Griffin ****s a big one - cheap*** **** at a high price. Been through a couple of them. Last one the epoxied tubes separated from the tank - non repairable so I bought a Walker....
  26. 36couper
    36couper
    from ontario
    The aluminum rad I had was a PRC. It started leaking at the bottom where the core met the lower tank. It had about 10,000 miles. The walker now has about 12,000 miles. Even with my a/c on on a hot summer day it won't go above 190. The aluminum rad at 190 and above even without any a/c. I ended up having to run an auxiliary fan
  27. 47chevycoupe
    47chevycoupe
    from Finland
    I had an O/T car with walker radiator. Started leaking a couple years after installed. Took to local shop to get fixed. Said it had too much bloom to be fixed. Bought a PRC had no problems. Sold the car about 6-7 years later and radiator was still in it.
  28. junk yard kid
    junk yard kid
    Well it was quite some time ago. There were a few reasons. I had an old original one for a 6cyl. It would over heat but i dont think it had a fan or maybe just no shroud. I was 16 and inexperienced and it was 1996 and the aluminum radiator was the hot ticket at the time. It took it a while before it leaked maybe 8-10 thousand miles. Ive only ever put 25000 miles on the car. Maybe leaking is too strong of a word, sweating is more like it. Aluminum may be stronger than copper/br***. But its more brittle and cars flex and move around a lot.
