1960 Buick control arms interchangeagle?
Discussion in 'The Hokey Ass Message Board' started by Mutt's37Buick, Nov 29, 2012.
  1. Mutt's37Buick
    Mutt's37Buick
    Can anyone tell me if the 1960 Buick Roadmaster control arms are interchangeagle with the 1960 Buick Le Saber?
    Thanks
  2. hidez57
    hidez57
  3. Mutt's37Buick
    Mutt's37Buick
    Thanks for the lead.
  4. TP
    TP
    from conroe tx
    I have an old interchange book that I'll dig out and see if I can find the answer. TP
  5. Mutt's37Buick
    Mutt's37Buick
    Thanks that would be great.
    Mutt
  6. Mutt's37Buick
    Mutt's37Buick
    TP
    While your looking, can you also check for interchangeability with the Electra.
    From pictures I 've seen, all three look similar.
    Thanks
    Mutt
  7. TP
    TP
    from conroe tx
    Yes I will it'll be tonight before I have time to do it if that's alright. Where is westminister? I'm about to kickoff a job in rangely[n.w. Colo in jan.]
  8. Mutt's37Buick
    Mutt's37Buick
    Westminster is a suburb northwest of Denver.
    Thanks a lot for your help.
  9. 51ChevPU
    51ChevPU
    from Arizona
    They should interchange. The difference in the electra and the lesabre had to do with the drivetrain and the length of the frame.
  10. lrlforfun
    lrlforfun
    OK Mutt: The same. Only difference is that 60 Bu's with factory a/c had a little stiffer spring to accommodate the weight of all that a/c stuff. Mitch
  11. heck they got camaro spindes on my 60 invicta and they are switched side to side, took some different top ball joints it looks like
    of course they put a leaf rear springs too
  12. Mutt's37Buick
    Mutt's37Buick
    Thanks for your help
