Taking pinstriping off
Discussion in 'The Hokey Ass Message Board' started by don's48, Mar 9, 2013.
  1. don's48
    don's48
    What can I use to remove pinstriping. I used oven cleaner on another car and it worked. I tried it this time and no luck. This is the same can I used before. Maybe it isn't as strong. I don't want to get aggresive because I don't want to re-paint, if possible.
  2. Painted or decal??...heat gun works great on decals....wetsand and polish???
  3. tfeverfred
    tfeverfred
    The same stuff that takes lettering off.:D
  4. Bugguts
    Bugguts
    I've used fine wet/dry sandpaper and buffed. Worked great. It was on a trunk lid and was way more than pinstripping. It was lettered Shake-Rattle and Roll. Came off real nice. I used 1000 grit and then 2000 grit. Ended up scuffing whole panel and buffing to give it all the same texture and look.
  5. It all depends on how it was put on .
    Decal - I'd get the eraser wheel
    Otherwise it would be some form of wet sanding
  6. don's48
    don's48
    Problem is, the tailgate has pinstriping on it, also. I would like to keep it if possible. What I want to take off is lettering, probably One Step paint. If I have to sand it, at least it's only the tailgate. Thanks, all.
  7. rd martin
    rd martin
    from indiana
    if your talking painted pin stripe, easyoff oven cleaner. if on top of enamel paint lightly put on small amount with small brush, let sit just 5 6 minutes, wipe with water. if on top clear small deal, just dont let it sit on there for long. you will see how long it has to sit on there after first try. if you have flat paint or primer dont use it, it will take it off to bare metal!
