Projects Martin Ford´32 5 Window Build
Discussion in 'The Hokey Ass Message Board' started by tmfcracing, Aug 29, 2011.
  1. tmfcracing
    tmfcracing
    from Sweden
    Tomas also help me with the trunk and rear quarter alignment, The left side felt a little twisted in the beginning but after some measurement we found oit that the left rear corner had been replaced and it is 3/8 to short. We removed the panel below the trunk lid and mounted it as it is supposed to be.
    Next thing is to work on the corner .
  2. tmfcracing
    tmfcracing
    from Sweden
    The material below the rounded beed is it short.
  3. tmfcracing
    tmfcracing
    from Sweden
    Did this little model for a reg-sign holder yesterday.
  4. tmfcracing
    tmfcracing
    from Sweden
  5. Awesome work Martin! Hey, just noticed, we're on page 32!!! :cool:
    Steve
  6. tmfcracing
    tmfcracing
    from Sweden
    Yes Steve , finaly at 32 :)
  7. tmfcracing
    tmfcracing
    from Sweden
    Hey Steve, I,ll send the Adler emblem to you and for the payment. How about you send me something fun,stupid,cool or whatever that you have on the shelf and dont have any use for.
  8. what a amazing build :)
  9. Sounds good!
    Steve
  10. tmfcracing
    tmfcracing
    from Sweden
    Someone not that smart in the past cut out the edge with holes that is used for attach the roof wood.
    I made a new edge and once again, weld/grind.
  11. tmfcracing
    tmfcracing
    from Sweden
  12. tmfcracing
    tmfcracing
    from Sweden
  13. BrerHair
    BrerHair
    You're a beast Martin.
  14. tmfcracing
    tmfcracing
    from Sweden
    Thanks Brer :)
    I need the location and diameter of these two holes in the quarter. Can someone help me out please :)
  15. KICKSY
    KICKSY
    Looking fantastic Martin, careful not to scratch that beautiful frame. :D
    Dave. :)
  16. tmfcracing
    tmfcracing
    from Sweden
    I'll be careful Dave ;)
    Done with the top of the grille/shell today.
    brEad likes this.
  17. tmfcracing
    tmfcracing
    from Sweden
    Now it flows with the hood-line :)
  18. tmfcracing
    tmfcracing
    from Sweden
    Also trying to get the trunk drain to work properly. As I understand the side trunk rain gussets are open in the bottom and the water goes strait on the trunk floor.
    I welded in a drain pipe in the back drain and adjusting the sides so the water from the side drains goes in to the back drain and then out thru the pipes.
  19. tmfcracing
    tmfcracing
    from Sweden
  20. alchemy
    alchemy
    Good idea on that trough reconfiguration. I'll have to do that on my roadster some day.
  21. Hotrodray
    Hotrodray
    from Sweden
  22. tmfcracing
    tmfcracing
    from Sweden
  23. 1928arat
    1928arat
    from australia
    Just read the whole thread all I can say is wow what a build.
  24. rcnut223
    rcnut223
    from wisconsin
    Man your killing me with the quality of your work!!
    Great stuff!
    I must be missing a trick on finishing the welds. Any chance you can go into some detail on how you are doing this?
    Mike
  25. rcnut223
    rcnut223
    from wisconsin
    When you added your drain in the trough, did this change the alignment of the decklid?
  26. ESGEE
    ESGEE
    from Sweden
    Just goon throu the build thread, love the fabrication work you do, keep the great work up...
  27. tmfcracing
    tmfcracing
    from Sweden
    Im not really sure I do it any differntly then anybody else, I start with the angle grinder and use a thick cut wheel just to get the top off on the welds and it makes less heat then starting with a sand disc . When there is little left of the weld I change to a sand flap disc to get it smooth. After that I change machine to a low rpm sanding unit. The same as car painters use and start with 80 grid and change to finer grit.
    I think the only trick is to take it slow and be patient , in the end its all about having the feeling.
    I,ll post some pics of the tools tomorrow :)
    I say wow to your kind comment :)
    Nope, not at all.
    I'll keep it up, thanks :)
  28. Bugguts
    Bugguts
    Wow. Just spent the better part of this evening enjoying your build and skill level. Nice job. Your designs really inspire me and makes me want to try new things. Thanks for all the hard work sharing this. Can't wait to see more.
  29. Tnomoldw
    Tnomoldw
  30. tmfcracing
    tmfcracing
    from Sweden
    Thanks Bugguts, I'll try keeping up with the posts:)
    You made me trying to test mounting the headlights today, thanks :)
