v-8 rear in a model a question
Discussion in 'The Hokey Ass Message Board' started by heyitsnate, Sep 21, 2005.
  1. heyitsnate
    heyitsnate
    i 'm stickin' a 39 banjo rear in my a,so how should i mount the rear spring? should i move my crossmember further back,or alter the 39 rear to run the spring on top using shackle mounts welded to the axle housings?
  2. kustomkoupe
    kustomkoupe
    it all depends on how you want the car to sit and how much trunk space you want to have and also if you DONT want to cut the frame
    id say if your planning to Z the frame and make it low your best bet would be to just lengthen it and run the spring behind
    just remember to make your extensions paralell otherwise they will get out to the edges of the body as they go back
    some of these parts suppliers do sell the pieces to weld to the top of your rear if you did indeed want to run the spring ontop though
    good luck
    zach
  3. heyitsnate
    heyitsnate
    my frame is already mildly z'd ...i never had a problem cutting anything up!..p.s. sorry rocky..i put me question in the wrong section..is it possible to move it to the main board?
  4. Automotive Stud
    Automotive Stud
    My dad's A has the stock A spring, minus a few leafs, with some new brackets welded on top of the banjo. Makes a clean, bolt in installation, but his car has a stock A frame other than the deuce K member.
  5. G V Gordon
    G V Gordon
    from Enid OK
    Nate, I'm running the stock A rear spring on Speedway shackles with my '46 rear using the original "46 mounts. I stepped and lengthened the frame with 2X4 tubing. I did keep the stock frame angle and it still has plenty of clearance for the body (tudor sedan, coupe may be narrower at the back). On mine it needed to have the rear crossmember set back about seven inches. I posted pic a couple weeks ago of the frame mods. Search for "Model A gets its A** Kicked".
    GV
  6. 28rpu
    28rpu
    Move the crossmember back. Easier to get the car lower than spring above axle.
  7. heyitsnate
    heyitsnate
    i found it ..i searched your profile,and that's exactly what i'll do! thanks gv!! i'll post pics when i get started...-nate
