1951-1952 Plymouth Cranbrook
Discussion in 'The Hokey Ass Message Board' started by Francranbrook, Mar 8, 2013.
  1. Francranbrook
    Francranbrook
    I just found a parts car that is a 1952. Does anybody know if the 51 and 52 are the same? I did a quick google search, but couldn't find the answer, so I thought I was ask here and not waste my time.
    Thanks.
    John
  2. LowerthanLife
    LowerthanLife
    you have a 51.
    and you just bought a 52.
  3. LowerthanLife
    LowerthanLife
    i just checked my chiltons and they designate '1951-52' for those years.
    yes.
  4. T Fritz
    T Fritz
  5. plym_46
    plym_46
    from central NY
    Mechanically pretty much everything the same or interchangeable, body parts and trim may differ. 51/52 share the same model number P-23, So the differences should be minimal. check the engine numbers. Stamped o a pad in the block above the Genny, they should both start with the P23 model number followed by other symbols and numbers.
    SinCityRatFink likes this.
  6. motorcade 1
    motorcade 1
    the same except hood ornament and licience plate light,width of center chrome strip on hood and color of dash.
  7. Francranbrook
    Francranbrook
    So,
    I got some pics of the car. It looks like my 1951 Cranbrook, but doesn't say on the fender what kind it is. The guy doesn't have a ***le and doesn't know what kind it is either. Here are a couple of pics, if I can get them to load. Anybody know for sure what it is? I need a trunk and some trim and front suspension parts for my 51 Cranbrook.
    Thanks.
    John
  8. Francranbrook
    Francranbrook
    Here are the pics, try #2.
  9. plym_46
    plym_46
    from central NY
    Cranbrook was the base model, so there would not be a lot of trim and fancy stuff. Does it have a clock? Factory signal lights, fancy trim on the window garnish, back seat ***ist straps, a rob cord across the rear of the front seat?
  10. BESTEKUSTOMS DENVER
    BESTEKUSTOMS DENVER
    from Denver
    The 52 has trim running down from the drip rail down in between the rear fenders and trunk making it a two-tone
  11. Rusty O'Toole
    Rusty O'Toole
    Practically the same except for minor trim differences. 49 - 50 the same basic body shell but a major face lift.
    Be careful, there was the regular line and a compact line comprising a 3 window coupe, fastback sedan and all steel station wagon all 2 doors. These had a shorter wheelbase and different bodies.
  12. kevin hardwick
    kevin hardwick
    I am restoring a 1951 Concord business man coupe, Although I have the coupe, I found all interior parts the grille the entire front clip will fit the cranbrook.
  13. kevin hardwick
    kevin hardwick
    1951 to 1952
