Chevy 3600 into a daily driver
Discussion in 'The Hokey Ass Message Board' started by Coach529, Sep 19, 2012.
  1. Coach529
    Coach529
    Thanks!!
  2. Coach529
    Coach529
    Just tinkered in the garage last in between hauling kids to swimming and household chores.
    Got the drive shaft shortened 1", welded back together and installed. Also did some more final welding on the front leaf spring mounts and started working on a punch list on what I have left to do.
    Spring is coming.....gotta get this baby done.
    My Cragars showed up, as well as my bullet lug nuts. Hopefully my tires show up today!!
  3. rusty1
    rusty1
    ...I'd suggest you set the bed on for weight and then mount your rear shackle mounts to get a true idea of the stance, I like the way you scored and bent the plates for the notch, good idea, never thot of that, your way gets the bend in the correct spot for sure. keep buildin, lookin good.
    btw, that bottom leaf is a helper/overload spring, when it comes into play it won't go down much further.
  4. 50 chevy matt
    50 chevy matt
    from UK
    Getting there and good to see you back on it :)
  5. Coach529
    Coach529
    I am kind of limited on how high I can place the rear spring mount. I am guessing even placed as high as possible I will still need some lowering blocks to get the ride height where I want it.
    I am also adding a sway bar which should stiffen it up a bit, as well as some good shocks.
  6. 48 Gimmy
    48 Gimmy
    Hi Coach! Nice looking pickup! I am enjoying your thread. I'm from Park River, and am working on a 48 GMC
  7. Coach529
    Coach529
    Welcome to the board.....and good luck on your build.
  8. rusty1
    rusty1
    ...I would think it'd be mounted lower than you now have it temporarily mounted once you put the bed on there...your outdoor pic looks pretty low or about level now.
  9. Coach529
    Coach529
    In that picture it is sitting with about the perfect amount of rake, in my opinion anyway. About 2-1/2" from front of running board to back of running board. This amount of rake makes the bottom of the windows parallel with the ground which looks great.
    Only problem is my tires I order are 1-1/2" taller than the tires that are on it now. With those mounted it will be too much rake I am afraid, but before I make any decisions the bed will get set on the frame and see how it settles.
  10. rusty1
    rusty1
    ...if your tires are 1 1/2 " taller, that only raises it up 3/4"...
  11. Coach529
    Coach529
  12. Coach529
    Coach529
    Very good point......
  13. shadams
    shadams
    Hurry up and mount those babies up so we can drool dammit, come on!
  14. Coach529
    Coach529
    I am trying......:)
  15. 50 chevy matt
    50 chevy matt
    from UK
    very nie indeed Mr Coach and im with Shadams as cant wait to see them on :)
  16. 50_Poncho
    50_Poncho
    Truck is turning out great! Makes me want to go out into the garage and start working on my pile!
  17. Coach529
    Coach529
    I could not find anybody to mount them in this one horse town today. Appointment made for Monday!! :-(
  18. Coach529
    Coach529
    Desperate times call for desperate measures. New tires and rims sitting here......and know body can mount and balance them until Monday. Ha.......I have done close to a thousand moto tires.....how hard can it be??
    Easy....about 5 min per tire.
    Nice clearance at full lock.
  19. NEWFISHER
    NEWFISHER
    from Oregon
    Looking better every week. Can't wait to see it with the bed on!
  20. Cymro
    Cymro
    How wide are your front wheels with which offset?
  21. Coach529
    Coach529
    6" wide, 3.5" offset.
  22. Coach529
    Coach529
    http://www.cragarwheel.com/products16-18/Crag****ries69Delux
  23. Gulfstream87
    Gulfstream87
    The truck is looking really good. I like the rims.
  24. volvobrynk
    volvobrynk
    from Denmark
    My pants got tight in a wonderful way, those wheels for perfect!
    I might have a minor crush on you truck now, nice built, keep going :)
  25. metalsurgeon
    metalsurgeon
    from UK
    Nice build i have a 1950 3600 which i'm doing a ground up on at the moment, keeping it stock, it was shipped from Washington, last year, should get cab back from paint shop this week and mounted on frame, having a bit trouble sourcing 8 lug wheels but other than that everything is going well, keep up the good work
  26. Coach529
    Coach529
    After some carb cleaner and some fire (on the backside of the tire) the rears seated easily.
    Bolted them on and am ready to rock and roll.
    First impression......wow they look awesome.
    Second impression....damn they look tall. 28" with 40 PSI in them......about 1" taller than advertised.
    Love the look though. Still waiting on my Shannon cones.
    Measurements show I will need some wheel spacers to clear the box sides. Probably 2" to fill up the wheel well as much as possible.
  27. 50 chevy matt
    50 chevy matt
    from UK
    superb stance on the front and looking sharp
  28. Coach529
    Coach529
    Thanks. I need to get the bed mounted and then play with the rear mounting to get my final ride height established.
  29. simplestone
    simplestone
    Those wheels & tires look great, and you've nailed the stance, too. It's been a pleasure following your build.
  30. 53 sparky
    53 sparky
    Really liking the build, Coach. The last set of pics were great. You've nailed the essence of the stance. Not too low, way better than stock.
