Projects Martin Ford´32 5 Window Build
Discussion in 'The Hokey Ass Message Board' started by tmfcracing, Aug 29, 2011.
  1. tmfcracing
    tmfcracing
    from Sweden
    As Hotrodray posted a link to a drawing for the rear fender holes yesterday I started to measuring them up and while doin it my friend Jon showed up.
    He had a new cellphone with an build in projector so this is how we did the holes.
  2. tmfcracing
    tmfcracing
    from Sweden
  3. n847
    n847
    Thats awesome!
  4. tomkelly88
    tomkelly88
    Are cell phone projectors HAMB friendly? ;)
    That's a pretty neat way of doing it.
  5. williebones
    williebones
    What cell phone is that, I must have it!!
  6. tmfcracing
    tmfcracing
    from Sweden
  7. tmfcracing
    tmfcracing
    from Sweden
    Mike, right or wrong. This is how I finishing the welds.
    I had to adjust the subrail to get the door closing properly.
    Here I used the tig and I make sure that both sides of the cut lines up together before welding.
  8. tmfcracing
    tmfcracing
    from Sweden
    The disc on the side is the one that I start with if its a mig weld and when there is a tig weld that doesnt build so much I start direct with the flap disc.
  9. tmfcracing
    tmfcracing
    from Sweden
    Weld gone with the flap disc, could get a little wavey as it such a small surfice bein grind
    [​IMG].
  10. tmfcracing
    tmfcracing
    from Sweden
    Changing to this low rpm machine , 80 grid and make sure the hole disc lies flat to the metal. Grinding on the edge of the paper is a no no.
    This removes the waves .
  11. tmfcracing
    tmfcracing
    from Sweden
  12. brady1929
    brady1929
    amazing, Martin
  13. tmfcracing
    tmfcracing
    from Sweden
    Thanks Brady :)
    Found these old marchal's on the second floor, I have no idea of what car they come from.
    They have a little lense on the top, maybe for turnsignal indicator.
    Any how, they works great sizewize.
    brEad likes this.
  14. tmfcracing
    tmfcracing
    from Sweden
  15. tmfcracing
    tmfcracing
    from Sweden
  16. James D
    James D
    Just loving this build!
    Anything new happening with your wheels?
  17. rcnut223
    rcnut223
    from wisconsin
    Martin
    Thanks for posting your process!! What amazing work , man you can lay down one nice bead with the tig.
    How does your door fit in the area you welded. Mine will need work wide at the front .
    Mike
  18. rcnut223
    rcnut223
    from wisconsin
    Martin
    Did you buy a new windshield frame? if so where did you get it and how is the fit?
    Mike
  19. davo461
    davo461
    Thank Heaven for traditional Samsung Galaxys ! lol
    I suspect that is a clever idea!
    Davo.
  20. tmfcracing
    tmfcracing
    from Sweden
    Yes, last friday I found a guy with a large cnc mill and he is going to help me out with the final machining.
    Still miss the front aluminum hoops but I got a text mess yesterday from Mike Curtis that they should be done till next week, he is making them thinner. And then it is shipping time .
  21. tmfcracing
    tmfcracing
    from Sweden
    My driver side door did hit the subrail in middle bottom but the p***enger door was better.
    The doors was about 1/2" to far out in the lower rear corner but Tomas just put some wood in the middle between the b-p and the door and bend with a hand in the top and a foot in the low corner.
    I was in shock to see how soft the doors are :)
    It is the stock windsheild, it in a really bad shape . Rotten underneth .
  22. tmfcracing
    tmfcracing
    from Sweden
    A-post after been choped long ago by some drunk american ;)
  23. tmfcracing
    tmfcracing
    from Sweden
  24. tmfcracing
    tmfcracing
    from Sweden
  25. tmfcracing
    tmfcracing
    from Sweden
  26. Lost Swede
    Lost Swede
    from Sweden
    Wink Wink. Looks good.
  27. charleyw
    charleyw
  28. tmfcracing
    tmfcracing
    from Sweden
    Started with the top trim for the shell today, it needs to be longer and another shape to fit the 32/adler front.
    Some hours still before its done.
  29. tmfcracing
    tmfcracing
    from Sweden
  30. tmfcracing
    tmfcracing
    from Sweden
    Something else .
