strunk fabrications new shop truck....er nova wagon build
Discussion in 'The Hokey Ass Message Board' started by 32coupedeville, Dec 2, 2012.
  1. loveoftiki
    loveoftiki
    from Livonia,Mi
    Drew...your are a "get **** done" kinda guy... Looks like you'r gonna need to make some road trips up here this Summer
  2. 32coupedeville
    32coupedeville
    from cincy
    yes me and the wifey have been looking at this years shows to figure out what we are doing. you guys in michigan seam to know how to put on shows!!!
  3. 32coupedeville
    32coupedeville
    from cincy
    the rears are 255 x60 x15 bfg's 28" tall and the fronts are 135 x 15 firestone f560 at 23.25" tall. the 135x15 are kinda small but i have run them on another nova wagon i had and they were fine. i may switch to 145 x15 's later but well see. one thing to note * firestone f560 series of tires run taller and have a bigger load rating than nankangs , michelin's , etc *
  4. 32coupedeville
    32coupedeville
    from cincy
    my plan it to make this little chevy 2 a road worrior.
  5. need louvers ?
    need louvers ?
    Man that stance is lookin' awsome!
  6. 32coupedeville
    32coupedeville
    from cincy
    here is a little update. i have been welding up all the holes in the floor i made to get the nova to set this low. i have been working on placement of all the gauges i will be wiring in. i kinda have a thing for gauges, alot of them. i made a 4 gauge mount for the radio area. also i wanted a gauge piller and there is none avaliable for the early nova's so i made one. i have been filling all the holes in the firewall as well.here are some pics:
  7. josh highley
    josh highley
    You are ate up with gauges and I love it!
  8. custom300
    custom300
    Looks good Drew can't wait to see it out.
  9. blackrat454
    blackrat454
    Curious, did you modify the front Tci crossmember much or just raise the shocks?
  10. 32coupedeville
    32coupedeville
    from cincy
  11. blackrat454
    blackrat454
    Thanks for the reply. I should have been more specific. I meant to say the front of the four link crossmember. After looking at the pictures again it appears you raised the center of the crossmember? Great build. I am just starting on my 65 wagon swap meet mobile.
  12. 32coupedeville
    32coupedeville
    from cincy
    sorry . i did raise the front of the tci rear kit x member 2 1/4". the very rear coilover x member i raised 3" by building a new x member all together.
  13. HOTRODPRIMER
    HOTRODPRIMER
    Great looking wagon,,are you going to paint and redo the interior? HRP
  14. Sparkswillfly
    Sparkswillfly
    from Colorado
    Awesome build - great stance!
  15. 32coupedeville
    32coupedeville
    from cincy
    yes i will be redoing the interior. the out side will stay for a few months but i hope to get it painted this fall or lastest winter.
  16. blackrat454
    blackrat454
    I have been considering this 4-link kit vs a universal ladder bar kit from a comlany like Alston. Do you have any input as to why
  17. blackrat454
    blackrat454
    You chose the 4-link kit
  18. S.F.
    S.F.
    nailed the stance
  19. 32coupedeville
    32coupedeville
    from cincy
    yes i chose the 4 link. i am NOT a fan of panhard bars but you have to have one with a streight 4 link. i would have rather did a triangulated 4 link but there just is no room under the seat. the bad part is the tci kit was like 1500.00 and i remade half of the kit because i went so low. i did not even used the coil over rear x member, i cut and raised the center x member were the 4 link bars hooked to in the front. then i took a very nice car and cut the floor all up! hey that is what it takes to get the stace just right. sacrifices.
  20. 32coupedeville
    32coupedeville
    from cincy
    just got so old eric von real wheels for the chevy 2 from charliechop1940. thanks so much. i will be send these 15 x10's out to eric von to be made into trick 8's for the back. i always wanted to get real rodder wheels for it but i jumped the gun and got torq thrust d wheels instead. i was not happy with them so erice von wheels it is. here is apic some one photoshopped for me of what it will look like.
  21. KustomCars
    KustomCars
    from Minnesota
  22. 41 C28
    41 C28
    Your wagon looks good. I recall little brother had one in high school in bc(before cool).
  23. 32coupedeville
    32coupedeville
    from cincy
    well i am itching to get this chevy 2 wagon on the road. i have had a few set backs. the front end was to wide. i had to narrow the upper and lower a arms 3/4 inch each. i got that done and it will turn now. ( turning is over rated!!!) i cant wait to get my wheels back from eric vaughn . he is narrowing my 15x10 real wheels to trick 8"s by taking the 2" off the back. i just finished insulating the car and i am working on the engine now. i have to cut the heads for bigger valve springs. the cam is installed and the short block is just waiting for the heads to ****on everything up. the show season is starting here and i want to have this wagon aout soon. more pics to come!!!
  24. blackrat454
    blackrat454
    Looking fotward to the pics. The back seat still gonna fold down with the floor notched? Also did you use dropped spindles with the z'd clip? The stance is killer. Gonna look awesome on the road.
  25. 32coupedeville
    32coupedeville
    from cincy
    the rear seat will fold down. i do have to narrow it just a bit thought. yes it has 2.5" dropped spindles and 3" front frame z with cut front springs . the lower a arms are level to the ground.
  26. blackrat454
    blackrat454
    Any progress pics?
  27. 32coupedeville
    32coupedeville
    from cincy
    yes but i got a new camera and i havent got the pics out of it yet! i will see way i can do..........
  28. 32coupedeville
    32coupedeville
    from cincy
    new pics of work up till now
  29. 32coupedeville
    32coupedeville
    from cincy
    getting real close to starting this sled!
  30. metal man
    metal man
    Will I see you and your dad at the swap meet tomorrow? Or Saturday?
