36 Chevy Sedan 2 Door Barn Find
Discussion in 'The Hokey Ass Message Board' started by zpi28, Mar 12, 2013.
  1. zpi28
    zpi28
    I got a message from a friend with a picture of this car and some trucks. I tell him thats a 36 Chevy and ask where is it, and is if for sale. So the next morning I hook up and drive 2 hours to pick up the car. Its in pretty solid shape minus the floors. I was told that it sat in a barn for 40 years in west TN with a dirt floor. The drivetrain is still intact, I believe its a 207ci 6cyl. I have 2 other projects in front of this one (53 chevy,64 Chevy trucks) but I could not p*** it up especially so close to me. I was expecting to drive up north or out west to get a car. Here it is.
    And one for inspiration
  2. black 62
    black 62
    from arkansas
    man you finished that fast---solid looking project good luck....
  3. zpi28
    zpi28
    That last picture is just for inspiration, I hope I can make this one that clean.
  4. 33sporttruck
    33sporttruck
    With exception to suicide doors and different grille shell the 36 is basically the same body style as the 35 Chevy that became the Chip Foose built car called "GrandMaster"
    Check this link: http://www.wildrods.com/feature/GrandMaster/index.html
    Make you want to Cry !!! Jeff
  5. Woob
    Woob
    from Falcon, CO
    Nice find.
    Be sure to post more pics when you start on it.
  6. zpi28
    zpi28
    Will do, I have already been researching parts. Im undecided on the driveline right now. Not sure if I want to use the original or go with a more modern one.
  7. manyolcars
    manyolcars
    I think its against the law to call it a barn find when we can clearly see that it was in a parking lot when you got it :)
  8. zpi28
    zpi28
    I hear ya, im glad it was already pulled from the barn when we loaded it up. One front wheel is locked up tight, but it was no match for the Case endloader that was hooked to it.
  9. HOTRODPRIMER
    HOTRODPRIMER
    Sure it was a barn find or found behind the barn?:D HRP
  10. GaryB
    GaryB
    from Reno,nv
    great find.one year only body metal,36 2dr couch(sp)parts can be very hard to find.but ch***is/drive line are easy peasy.lots of room lots of options,good luck.had to sell mine.divorce
  11. zpi28
    zpi28
    Got more pictures this afternoon. Looks like the leafs were wrapped with something at some time. The oil level is a little low but its clean. :)
  12. Dizzie
    Dizzie
    Nice find. We have a '36 sedan delivery with a 400 small block in it. Looks like yours needs door wood work. A little tricky to get new wood in and adjusted properly.
  13. monkeyspunk79
    monkeyspunk79
    Good score. I didn't realize '36 Chevy cars still had so much wood in them until recently. I thought that was the turning point when more metal went into the structure. Either way, you got a nice sedan to build on. Good luck with her.
  14. zpi28
    zpi28
    I noticed all the wood after I loaded it on the trailer. None the less I was glad to find this one close by. Thanks Im glad to see that I can still find some sheetmetal for it. Im going to start practicing my oxy/act welding before I begin this one.
  15. 55 dude
    55 dude
    Looks like a master deluxe with the crome headlight buckets. Hope you know s good carpenter.
  16. Okatoma cruiser
    Okatoma cruiser
    from Ms
    Nice project you have there-- are you gonna restore it or make it a cruiser?
  17. zpi28
    zpi28
    Going to make it a cruiser, keep all the fenders and running boards. 113" WB , going to look for a match and put a modern running gear under it.
  18. zpi28
    zpi28
    I know a metal carpenter and he is going to use some 1" sqaure tubing to fight off the termites. :D
