Projects 38 ford coupe from downunder downunderIve done
Discussion in 'The Hokey Ass Message Board' started by mercurymitch, Jun 11, 2011.
  1. Tim
    Tim
    from KCMO
    wow, just amazing
  2. scott 351 wins
    scott 351 wins
    Wow you sure are a talented metal shaper!!!!!!!!! I just bought a 39 ford standard coupe that's in similar condition, your build is very inspiring to say the least.
  3. mercurymitch
    mercurymitch
    from Australia
    Been busy at work so car has been a bit slow,getting doors welded up and ready for skins
  4. mercurymitch
    mercurymitch
    from Australia
  5. mercurymitch
    mercurymitch
    from Australia
  6. charleyw
    charleyw
    I just found this.............outstanding work, very inspiring. Subscribed
  7. zibo
    zibo
    from dago ca
    Love the door interior design.
    Any pics to see how the door/dash area looks closed?
    TP
  8. You sir,are the epitome of the poster "Devil with a Hammer...And Hell with a Torch!" I envy your talent! Bully! I say...Bully!!!
  9. mercurymitch
    mercurymitch
    from Australia
    I was going to use solonoids and micro switches to operate the internal door handles,but if the alternater stopped working and battery went flat i would not be able to get out,so i have used accelerator cables bought on ebay to opperate the handles [​IMG]
  10. mercurymitch
    mercurymitch
    from Australia
  11. mercurymitch
    mercurymitch
    from Australia
    I used a GMH roof to make a door skin and had to wheel it up a bit more ,this was before Christmas
    [​IMG][/IMG]
  12. mercurymitch
    mercurymitch
    from Australia
    Photo bucket wont let me post img
  13. Janice584
    Janice584
    from usa
    Made up some side panels and used 1/4 windows from a 39 sedan ,the sides are the second attempt[​IMG][​IMG][​IMG][​IMG]
  14. tbauer
    tbauer
    Your build is proof that anything can be accomplished with minimum tools and maximum brains!
  15. Wow, what a great job. And i was thinking my 39 Merc coupe was in a bad state ;)
    Hennie
  16. mercurymitch
    mercurymitch
    from Australia
  17. mercurymitch
    mercurymitch
    from Australia
    Just put the img up without going through the [insert image] icon and it works
  18. mercurymitch
    mercurymitch
    from Australia
    Had an accident in my tow truck in Jan.and been off work with two crushed vertebrea so limited to what i can do ,darned my sox ,sharpened all the neighbours drill bits,sharpened 15 hand saws then started making brackets for the rod,much to HAM BERS disgust.Started with some ally from the scrappy
    [​IMG]Then got to work on the CNC machine to make exaust brackets
  19. 40fordtudor
    40fordtudor
    When we were building the 40 I straightened the deck lid and the front fenders some and thought I'd done something. This is an outstanding thread.
  20. mercurymitch
    mercurymitch
    from Australia
    CnC machine in my workshop means cut n curse.Then out with the wood router and round the edges off
  21. RMR&C
    RMR&C
    from NW Montana
    Fantastic work! Wish i had a fraction of your talent.....
  22. mercurymitch
    mercurymitch
    from Australia
    Made some kick panels on the bead roller
  23. mercurymitch
    mercurymitch
    from Australia
    Finally got the floors welded in
    and the seat mount in
  24. speed v8
    speed v8
    Great fabrication work here! Nice.
  25. ausbuick
    ausbuick
    good work mate
  26. druids62
    druids62
    I just read this thread from start to finish at 6:30 AM. INCREDIBLE! Thanks for the morning inspiration mercurymitch!
  27. mercurymitch
    mercurymitch
    from Australia
    I did not have any window reveils so had to modify some dodge sedan ones.
  28. mercurymitch
    mercurymitch
    from Australia
    Made these panels to support the trim in the rear.
    And also made and welded the seat belt mounts in.
  29. rodl
    rodl
    Mitch, your workmanship and dedication to the job really inspire me. You've obviously 'got over' the chemical poisoning. Good luck to you mate!
    Rodl
  30. mercurymitch
    mercurymitch
    from Australia
    Made the rear seat riser
    I also used a seat which needed the floor for support as the base is mainly foam
