Which one , short or long ?
Discussion in 'The Hokey Ass Message Board' started by FANTM58, Mar 16, 2013.
  1. FANTM58
    FANTM58
    I want to remove 1 of my rear leaf springs to drop
    The rear level with the front .
    It has 5 springs , the bottom one is short then the rest ,,
    Longer ,
    Do I take out the short one or one of the long ones?
  2. kscarguy
    kscarguy
    You could change the shackle length or put in lowering blocks (if the spring is under the axle) to drop it. It would lower it but not effect the ride quality.
  3. FANTM58
    FANTM58
    The axel is under the springs
    I'll have to look ,but I thing the shackles are already short .
  4. davidwilson
    davidwilson
    from Tennessee
    take the short leaf out
  5. 65standard
    65standard
    You could de-arch the leafs
  6. Razorshotrods
    Razorshotrods
    from Phoenix
    take out 2, you only need 3.
