Scored a Burns manifold off Craigslist today
Discussion in 'The Hokey Ass Message Board' started by jim1932, Feb 20, 2013.
  1. jim1932
    jim1932
    Listed as a "Vintage Ford Manifold" It is an old one, his father had it for 30 years he said. looks a little odd because he sandblasted it to "clean it up".
  2. bonesy
    bonesy
  3. Steel A Rod
    Steel A Rod
  4. jim1932
    jim1932
    Although my 32 tudor is a bone stock car, I am trying to ac***ulate the pieces to mildly rod it when I get bored. A dual carb set up and some artillery wheels should do nicely.
  5. magneto57
    magneto57
    Lucky fined.................rich
  6. Mopar Jack
    Mopar Jack
  7. brett4christ
    brett4christ
    Good score! I picked one up a little while back...kinda wished someone hadn't installed a vacuum port in the middle of the "R"!!!!
  8. jim1932
    jim1932
    So for a stock B motor, what would be the recommended Carbs to run on this? I know the 81's are the most popular, but I tend towards the less common.
  9. brett4christ
    brett4christ
    From what I've read, (I'm new to this banger stuff) the carb of choice is the Stromberg 81. I can't afford 2 of them, so I'm going with 2 Holley 94's as I have several and can afford to experiment with them. I'm hoping I can jet them down and maybe run "restrictor plates" to reduce the CFM's to the engine.
    I've seen several other carbs applied. Another option I'll look into if the 94's don't work, is I've seen adapters that will mount 3-bolt 94/97-type carb bases to 2-bolt one-barrel manifolds. If you flip the adapters over, you can mount 2-bolt carbs to 3-bolt manifolds. Maybe......
  10. manyolcars
    manyolcars
    I have a Burns valve cover. Anyone know the history for Burns?
  11. Jim,
    Congratulations on that SuperBowl Win ... ;)
    Nice CL score !
    Jim
  12. lht
    lht
    i never find good stuff on cl
  13. brett4christ
    brett4christ
    Hey Skid,
    These L-6 carbs you mentioned....were these suggested for me or the OP? Seems two of these would be overkill for a banger, too! Gl*** bowls WOULD look cool on that manifold, though! :D
  14. jim1932
    jim1932
    anyone have photo's of one of these set up?
  15. aircap
    aircap
    Righteous find!
  16. Nailhead Jeff
    Nailhead Jeff
    from fresno
    Run the 2 94's. I ran 2 on an otherwise stock Model A engine. 53 jets and 3.5 power valves. It worked great.
  17. brett4christ
    brett4christ
    Thanks, Jeff! I knew somebody must have ran this setup before! Did you have to restrict the airflow at all? Also, did you set them for straight or progressive throttle linkage?
    I was planning to cut some spacers out of 1/2" aluminum, drill 7/8" holes, then blend them to "port match" the carb venturis. Would this help at all?
  18. winduptoy
    winduptoy
    Great find. It is nice when something gets into the hands of someone that is going to do something with it.
    I'm still learning and I tried a set up that someone gave me (a great score) as he is a bowtie guy and it is a Burns intake and model 81 carb, not bowtie kind of stuff. I'm at 7000' elevation and that is a problem also.
    The single 81 isn't enough carb and I was trying to figure all this out for myself. I got to learn something that someone else already knew. I stumbled on to a web site 'Mr Stromberg'. They have a CFM calculator. Just using their default for volumetric efficiency the single 81 isn't enough for a 200 CI 'B' motor at 3500 rpm ...if I had gone there first. The calculator tells me that the engine requires roughly 168 CFM. This closer to a 97 or even better yet a model 48.
    My understanding is that the 81 does about 125 cfm and a 97 does around 155 cfm and the 48 about 170 cfm.
    I all of this is X2 for a dual carb set up I suspect.
    Now I have a dual carb set up for the 'B' motor with a different head and cam so the VE changed. I have dual 81's on it now and it runs really well but rich at this al***ude with stock jets and power valve. I need to rejet. All this came with help from rickshelton@gasalleystreetrods.com (Mr Stromberg) He is helpful and gives you data not just an opinion, not that opinions don't count they just don't always solve problems.
    Goos luck and I want to see how you go with your approach with your set up.
    LJ
  19. FiddyFour
    FiddyFour
    great score
    flat six fords ran holley 847 carbs, and they look just like 94's... but yeah, holley 1904 gl*** bowls would look the bomb on that intake... trouble is getting two 1904's that are matched (so many different variants made) and then getting them to work well in a group
  20. jim1932
    jim1932
    What do you look for to know they are matched? Are there secondary numbers?
    Jeff, any photos of your setup?
  21. jim1932
    jim1932
    It that a cover for a banger? Got pbotos?
  22. magneto57
    magneto57
    Cooooooool............rich
  23. Hotrodmyk
    Hotrodmyk
    x2!
  24. jim1932
    jim1932
    The key is to look for poorly labeled stuff. This one was under Vintage Ford intake. I search under vintage ford, flathead, antiques ford. Misspellings of Stromberg and holley
  25. 50shoe
    50shoe
    Nice. I emailed the guy but you beat me to it! :)
  26. chopo
    chopo
    i need one..... a single carb or double anyone got a spare?
  27. jim1932
    jim1932
    A burns? Or a manifold?
  28. brett4christ
    brett4christ
  29. Ricks57
    Ricks57
    from San Diego
    Here are some too big carbs on an Evans intake. Ran best with one carb closed off. Hasn't been really tuned in yet. My buddy Russ's car.
    Rick
  30. jim1932
    jim1932
