how do these look?
Discussion in 'The Hokey Ass Message Board' started by big vic, Mar 18, 2013.
  1. big vic
    big vic
    from cary il
    Bought a set of these yesterday I think theyre cal custom but not sure,,,,, I like the way they look but wanted some input before drilling my nice valve covers,,, what I like about them is I ve never seen a set like this before i need breathers because since i mounted these valve covers i have had oil blowing out the oil fill tube,
  2. big vic
    big vic
    from cary il
    any comments will be apretiated
  3. 65PANELRAT
    65PANELRAT
    They look Nice, similar to mine. You did not indicate if you are running a down draft tube or PCV valve?
  4. Jalopy Joker
    Jalopy Joker
    what type of valve covers did you have before? is that rectangular piece at upper side of valve cover a breather? I think I see a breather tube at front of intake manifold, correct? no rear breather tube? no PCV? going to reroute spark plug wires? VC on 65PANELRAT looks to be set up wrong. since it seems to have PCV on one side and a regular breather on top of opposite side with breathers on sides too - defeats the system have too many breathers and not enough.
  5. Deloc
    Deloc
    I have a pair of Cal-Custom covers on a 350 SBC and the same issue with breathers, I don't want to add holes to them. I found adding a PCV valve system to the intake manifold along with the old style oil fill tube works.
    Deloc
  6. big vic
    big vic
    from cary il
    i had a set of m/t with a pcv since i mounted the edelbrocks i m having the problem,,, i read the threads about a pcv and plan on adding one ,, but thought some breathers would look kool also adding to the fresh air going in,, the rectangle at the top is the breather i just have it set on there for now seeing how it looks
  7. chalkboard
    chalkboard
    I'm pretty sure that if they say Edelbrock that they are Edelbrock, not Cal Custom.
    They do look good.
  8. I think he's referring to the breathers...
  9. black 62
    black 62
    from arkansas
    look great...
  10. big vic
    big vic
    from cary il
    yes i m talking about the breathers thanks for the feedback,, and yes i m gonna route the plug wires better
  11. Blue One
    Blue One
    from Alberta
    If you had a PCV before and now you have none, just mounting breathers on the valve covers will not solve your problem.
    I think you should return the breathers, (I have always thought they look cheesy anyway) and hook up a proper PCV system to solve your problem.
  12. big vic
    big vic
    from cary il
    do you think a pcv and the breather on the oil fill tube will be enough? in the pcv thread it shows how to mount one in the back of the manifold or at the carb base and i think i could do that no problem but didnt know if it would be enough fresh air coming in
  13. fifty5rod
    fifty5rod
    from El Paso TX
    Those are sweet!!
    Sent from my DROID device using the TJJ mobile app
  14. they look real nice, but the hei kinda kills the look..no offense, but be nice to swap that out at some point...
  15. verno30
    verno30
    x2. I have had luck building a PCV system into the intake and getting away with not running any breathers in the valve covers. PM me if you have questions.
  16. big vic
    big vic
    from cary il
    i have a vintage distributer in the works but wont have it ready for awhile
  17. big vic
    big vic
    from cary il
    pm sent
  18. slammed
    slammed
    Big time YES!
  19. chopo
    chopo
    they make your **** look big :)
  20. Blue One
    Blue One
    from Alberta
    With a proper PCV venting the crankcase the air being taken into the fill tube breather will be enough.
  21. moparmuscle1
    moparmuscle1
  22. 54rat210
    54rat210
  23. nice to hear you have a distributor that will be ready soon, you engine is looking nice!
  24. 1931modela
    1931modela
    from montana
    On what you got going there, they look fine... IMO im not a fan of the HEI, chrome alt and big air cleaner. But as I said on that ride they fit fine
  25. Fopelaez
    Fopelaez
    I put my Moon ones on the other side to have more space by the carb, but I still want a hidden PCV.
  26. Ragtop
    Ragtop
    That's a great look, but don't you have problems with oil settling into them?
  27. big vic
    big vic
    from cary il
    Fopelaez,, that looks great,,,
