How good (or bad) are moulded dash covers?
Discussion in 'The Hokey Ass Message Board' started by Dimadee, Mar 19, 2013.
  1. Dimadee
    Dimadee
    My '60 Cadillac has a couple of cracks in the dash (don't they all?), and the previous owner thought some carpet and double sided tape would fix everything. Not wanting to keep the rug on the dash, so I started looking for alternatives.
    I found some moulded dash covers which you place over the existing dash at stockinteriors.com. They sound like a great idea as long as the preparation and install is done correctly.
    Has anyone used these covers before? If you have, how do they look? Some pictures would be great.
  2. HOTRODPRIMER
    HOTRODPRIMER
    I used one on a mustang and it was a vast improvement,,,I'm positive it looks much better than carpet! HRP
  3. x2 my 69 stang was improved with one
  4. ken05k
    ken05k
    from Jasper, AR
    I put one on my O/T 72 Ford pickup and it made a world of difference.
  5. iammarvin
    iammarvin
    from Tulare, Ca
    On my old off topic Ghia, just covered the original with vynal,vinel, vinal....whatever, you all know what I'm talking about, left out the speaker holes, looked great didn't cost much. That $150 is almost to cheap to recover your own.
  6. Dimadee
    Dimadee
    Thanks guys....any pictures?
  7. tb33anda3rd
    tb33anda3rd
    are you talking about, just a slip over cover? or the type you send out your old dash and they mould a new cover on? i have had a couple redone by "just dashes" and they came out perfect. expensive but perfect.
  8. ffr1222k
    ffr1222k
    I put a Coverlay molded cover on my '88 TurboCoupe 7 years ago. It still looks good. I think it was about $60.
  9. SaltCityCustoms
    SaltCityCustoms
    I put one on an MGB awhile back and you couldn't tell it had a cover on it.
  10. camcb
    camcb
    We put one in my daughters 97 Firebird and was a huge improvement $140 I think.
  11. 56premiere
    56premiere
    how about a tuck & roll one that is made to slip on like the carpet one?That would give you something nice. I used to sell and install coverlay's ,they were an improvement.Also made some t & r ones. Jack
  12. Dimadee
    Dimadee
    Hi Jack,
    I am not sure what you mean by tuck and roll. Can you explain a little more?
    ...tim
  13. I put a coverlay brand molded dash on a Chevy truck (73-87 style) in 2006. It fit damn near perfectly and looks just like the day I put it on. Spent most of those 7 years outside too.
    It looks great but you do loose the "padded" ness of the original
  14. 56premiere
    56premiere
    We used to sew up the t & r and cut to fit,then bind the edges. Made the dash look custom. This was not a complete recovering that required dis***embly , merely a lay over. Good luck Jack
  15. shivasdad
    shivasdad
    from Texas
    I put one on a Bronco last year and it worked great. Clean well and use the adhesive per their instructions. I did it with the dash out because I had it out anyway, so it was easy.It would not be too hard with everything in place though.
  16. WB69
    WB69
    from Kansas
    Put one on my 69 mustang about 10 years ago, still looks very good. But always kept inside with cover over car, no direct sunlight for very long at any time.
  17. 41 1ton
    41 1ton
    I have one on my O/T 77 f150, still looks great 10 years later, always parked outside and sees a lot of spills etc. while offroading.
  18. chinarus
    chinarus
    from Georgia
    **** or Loop?
  19. Dimadee
    Dimadee
    Thanks all for your contribution. It sounds like it is the way to go.
    Now all I need to do is decide on the colour. The original interior colour was black however the last owner changed it to red (including spraying the dash!).
    I think the red would look stunning when done properly, especially when I can afford to have the bodywork done and respray back to the original silver (currently black).
  20. HOTRODPRIMER
    HOTRODPRIMER
    If you read the OP's original thread it should be apparent I was referring to his 1960 Caddy with carpet on the dash! :rolleyes:
    He never mentioned the style. HRP
  21. Dimadee
    Dimadee
    ****-adellic baby!!! ;-)
